Difficilty on doing this, also how did you tap into the pins for the ECU?
As much info as you can give would be appreciated!
Anyone installed an Apexi AVC-R?
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
I have the AVC-R in my turbo for almost 4 years and it does a good job and I still playing around the setting.....
For the installation, follow the given manual or download it from Apex-i website and looking for BC5 for sedan or BF5 for Wagon, but both should be the same. All the pin from ECU are the same as the JDM so just follow it.
I using quick splice connector (those blue clip that connect 2 wires) those are easy and save to use and it work for me over 4 years without any problem.
Here are some info for installation from Japanese Subaru fans and you could take a look and see how there installation or unit set-up:
http://shinnosuke.web.infoseek.co.jp/AVC-R.html
http://impreza.pekori.jp/gdb_tuning/gd_tuning22.html
http://64.233.161.104/search?q=cache:HS ... 0target=nw
Hope it helps.
Ben
Hope it helps.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
