not really a legacy topic but...
TurboSubie
Post by TurboSubie »
I managed to get a 91 subaru Loyale wagon for $200..needs a wheel bearing..its 5 speed with 152k...it has a check engine light on...what is the procedure for finding out what the code is...is it similar to the legacy?
1994 Aegian Blue Subaru Legacy Sport Sedan. Mean Muggin.
1995 Honda CBR 600 F3 D&D complete system,K&N, few other things..
magicmike
Post by magicmike »
yes and no. the ecu is located directly under the steering column. tilt the clumn up and stick your hand in there and pull the black foam down and you'll see a little hole. the led is in there. If I'm not mistaken you might have to connect the two green plugs located in the engine bay next to the left front strut tower. I'm pretty sure I never connected those and still got codes. Once you get them I can look them up for you. I have a few chiltons and a haynes for the gl's loyal. on second though I had an 87 so maybe everything I just told you is wrong. well give it a try it cant hurt
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
My '84 wagon had a blinking ECM also, but I have no idea what it looked at or controlled unless it was for the transmission. Hmm, that's probably what it was.
