heater motor not working
su bar u guy
Post by su bar u guy »
hey, my 91 heater motor won't work on any speed. So far I changed the speed control with one that I know works. Then I checked for power at the motor.( None) any thoughts?
ciper
Post by ciper »
Have you checked the resistor inside the dash?
su bar u guy
No. Where in the dash is it located, and what does it look like?
if you pull the glove box it's pretty much directly in front of you. It's inside the evaporator box.
su bar u guy
:) Thanks I'm gonna check it out right now.
su bar u guy
i tested the power supply plug to the relay and no power. Whats next?
123c
Post by 123c »
You need part number 72024AA000... I replaced mine 2 weeks ago, and the part was $50 at the dealership...
1971 VW Super Beetle
1989 Honda Elite 50
[/color][/b]
su bar u guy
What is it and where is it located?
123c
Post by 123c »
It's a resistor, and it's located behind the glove box. It's white, and it has some wires plugged into it. It takes less than 10 minutes to replace it.
1989 Honda Elite 50
[/color][/b]
su bar u guy
I tested each of the termonals inside that plug with the key on and the blower switch on and I don't have power in any of them. That's kinda why I ruled that resistor out. I checked the two fuses under the dash in the fuse box and there ok. I don't have power at the blower motor either. Any thoughts?
su bar u guy
Just wondering does anyone alse have any ideas?
su bar u guy
Hey guys, I found my problem. It took a while, but it turned out to be a Relay on the drivers side above the fuse box.
Oh, duh, the main fan relay... I shoulda thought of that. Sorry about that.
Nice work figuring it out. Did you have to get a new relay for lots of money from a dealer, or is there an aftermarket replacement?
su bar u guy
I was lucky. I have a 90 LS wagon parts car. It had the same relay. :D
