LOOKING FOR TURBO FOR A 1997 2.5gt
KRVT
Post by KRVT »
i have had my subaru for about 4 months now and i love the car. ive been looking to upgrade but have found it very hard to find parts for my legacy . i was wondering if anyone could help me out in finding a good turbo, ive looked all over the internet and have found nothing.
thanx
-kevin
rallysam
Post by rallysam »
Look for a kit for an Impreza 2.5RS since it has basically the same engine. Obviously, it won't be a simple bolt-on but it might not be too difficult.
On your engine, best to keep the boost reasonable since it wasn't built for turbo. Great car, though.
'00 Impr RS - sold
gt2.5turbo
Post by gt2.5turbo »
lthis one would kick some serious power for you.... has eventhing you need except i think you might need a new crossmembe....
http://www.forcedairtech.com/stage3.html
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
The forced air kits are pretty good. I believe with his kits, you don't even need to swap crossmembers
gt2.5turbo
yeah i was orignally going to pick this kit up and a gt model legacy until i found my turbo wag.
then it was love...
rallysam
Post by rallysam »
gt2.5turbo wrote:yeah i was orignally going to pick this kit up and a gt model legacy until i found my turbo wag.
then it was love...
I'm confused. Originally you were going to do that but not any more? But your post from yesterday says that you DO have a GT model legacy and you ARE looking for a turbo kit for it.
'00 Impr RS - sold
Binford
Post by Binford »
Different person.^
scottzg
Post by scottzg »
for the sake of discussion, would it make sense to go with a 2.2 over a 2.5 for turboing? Obviously a turbo motor makes more sense for real power gains.
Matt Monson
Post by Matt Monson »
KRVT,
NO NEED to yell at us to get a response!
I second the suggestion to get the FAT kit. They make it for both the 2.2l and 2.5l cars.
As for the which engine question? Obviously the 2.2T is better suited to boosting with it's lower CR. But when you already have the flow of the DOHC Ej25 heads, it is hard to argue that it will make more power in this car. 5-6psi on an Ej25 is good for low to mid 200's in the power department. And the beauty of the FAT kit, is later, one can replace their block with, say, an Ej257 STi bottom end and lower the compression and turn up the boost and make 300hp...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
rallysam
Post by rallysam »
rallysam wrote:I'm confused. Originally you were going to do that but not any more? But your post from yesterday says that you DO have a GT model legacy and you ARE looking for a turbo kit for it.
Binford wrote:Different person.^
DOH! brain fart!
'00 Impr RS - sold
KRVT
Post by KRVT »
wow. i apreciate everything i will definetly take all your help.
thanx
-KRVT
