i would like some help on makeing a factory set of cams into a very hp set of cams.
my list of mods on my car is huge, you name it i got it done. the only thing that is not done, is in side the motor. everything is built to last and take a beating.
so what cam spec could i make my factory cams in to, the max spec but i dont want to change nothing else, the cams have to work good with the factory internals, my heads are ported the same size as the 2.5ls also.
ej22t cams
ej22t cams
