Mashed Frame
92BlackBeauty
Mashed Frame
Post by 92BlackBeauty »
So I smashed up the front corner of my 92 SS and was wondering how hard it will be to cut the frame and bend it?
My right front fender is smashed, and it bent the frame that holds the hood and hood latch down.
This frame seems to be welded to the actual frame of the car, so it will most likely involve cutting/grinding.
Has anyone experienced this? How hard was it to fix?
92 SS--up and running finally!!
(edited for Jason Grahns pleasure)
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
I think it just unbolts. mine got fucked when i wrecked my car
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Kelly
Post by Kelly »
I beleive its spot welded, and thats not a frame, its the "core support"
Drill it out at the spot welds, get a new pice and reweld as original. That's how they do new car damages when the insurance foots the bill.
Kelly
Post by Kelly »
ya, cept a good body man will grind down, and bondo the new spot welds.
If they use the original locations for the spot welds and want the car to look stock, they won't bondo them. They even have spot welding 'dent' tools to replicate factory spot welds for anal restoration jobs. I personally, want seam welding.
92BlackBeauty
Wow, that's exactly what happened to my car.
Anyone have an idea how much this would cost at a body shop?
LaureltheQueen
Spelling Nazi
Spelling Nazi
are you referring to the photo, or the description above it?
Bheinen74
Post by Bheinen74 »
if you go to any body shop, they can pull up the part (front raditor core support) and it will give the bodyman an estimate for hours, and thye generally charge 45 an hour. for my wreck, just the lower center radiator support is 2 hours labor, so 90 bucks to put in the new piece. not that bad. Yours will be more cause it is the whole support not just lower center.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
