no turbo coolant tank
Skip
Post by Skip »
I found out my 94 turbo has no coolant tank
(the one on top by the master cyl)
is this an issue I should deal with immediately
ambient temp 85 plus
thanks for any replies
Matt Monson
Post by Matt Monson »
What do you mean it has no tank? Have they re-routed the lines so the turbo still gets some sort of cooling, or what? Can you provide some pictures of your engine bay?
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Even if your turbo's not getting any coolant at all, you're not going to cause any immediate damage if you make sure never to park the car with the turbo hot. That means you should idle or run at low loads/RPMs for a few minutes before parking. And of course change the oil regularly, using a good synthetic lube. I'm not water-cooling my TD05-16G right now.
But the bigger concern is about your radiator cap... Did they relocate it somewhere else? A missing cap or one in a bad place could be a bigger problem.
Skip
Post by Skip »
First let me say thanks for the replies.
I must admit this is my first Legacy turbo, just got it on the road
I have owned multiple EA82Ts and know that engine pretty well.
I did not know I was suppose to have this what appears to be a "swirl tank"
The hoses that use to go to it, are connected as a by pass it seems.
The rad is from a non turbo unit and has a factory cap on it for pressure control.
Thanks again and I do do a cool down time after driving
Ah. If the hoses that used to go there are hooked to each other, your turbo's still watercooled. You just don't get the after-parking cooling effect that the tank normally allows for. So idling after driving should be fine.
The non-turbo radiator should be good enough; it's a bit oversized for its original application anyway. When you start making a lot more power than stock it may become an issue.
If you want to see what the original plumbing was like, look here:
http://www.graphics.cornell.edu/~v/pics ... ooling.png
Skip
Post by Skip »
Vikash, thanks for the support and the excellent
picture of the orig plumbing
I am going to try and sort out what has been done to mine.
On your scan
I see the output line from the turbo but not where the input line
connects to.
EA82Ts have a connection to the head in this location.
You're welcome.
So do EJ22Ts... I guess I could add that line to the diagram. I'll see if I can do it neatly.
But, yeah, that lower coolant pipe on the turbo connects to a C-shaped hose that connects to a pipe attached to the passenger-side cylinder head with a banjo fitting. It's probably exactly like the EA82T.
Skip
Post by Skip »
thanks again guys
I had a look here is what I've got
the long thin hard line from the rad
to the tank has no hoses on either end
(non turbo rads do not have a fitting)
The hose from the turbo is connected to the hose
that runs to the H20 pump thermostat housing.
The overflow tank is in the normal position and
connected to the rad cap neck as per normal n/a setups
Temp gauge sits just south of half way, after bighill climbs it is
level or at the half way mark.
(Josh I appreciate your help most heartily, and at one time I could link
to your excellent pages but my server can not connect to it these days)
Skip wrote:the long thin hard line from the rad
Sounds right.
Sounds right.
Sounds right.
Hmm... I guess that's right. Though I wouldn't really expect to see the temperature rise that much. Can you hook up my scantool and see what the water temperature is?
Maybe you have a firewall blocking port 8080. Try this:
https://www.main.experiencetherave.com/ ... P_4265.JPG
If you get a complaint from your browser about the certificate, ignore it.
this one won't give you the complaint :)
Skip
Post by Skip »
yep, thanks.. that one worked fine as did Vikash's
I see now the hose in question and some other interesting parts
very kewl
I have not put the laptop in her yet to see the real temp
but the gauge reads very similar to my NA 84 GT wagon.
leaving for vay kay tomorrow (not in her)
will investigate further when I return
again thanks for the help guys
nice getting intelligent answers so quickly
