Idle valve problems down under Australia ej20 motor in Trike
seagull
Post by seagull »
Gday to all I am new to the forum and seeking some help
I have built a custom bike ( trike ) over the last two years , I recall legacy777 refering me here Josh ?
My ecu numbers are as follows and is a three plug ecu
T4
22611 AB371
A18-000RW6
the motor is from a jap import legacy 1994 BG5A56E and is a EJ20 quad cam n/asperated
can any one please help me with a wiring diagram for this as the fault light is reading 3 - 9 ( 39 ) i think this is 30 & 9
the motor idle valve is opening and closing ( motor idle is up & down )
I have been looking and asking for 7 weeks now and still can not get this sorted , aprecate you assistance
cheers from Seagull ( neil ) down under Australia
Hey Neil,
Other forum I forgot to mention is http://www.rslibertyclub.org/forums/
They are mostly first gen legacies, however they can probably refer you to a second gen legacy board for australia based people. (assuming there is one)
seagull
Post by seagull »
Hey Josh , been a long time .
The trike is almost now done , just sort the above problem out .
I will have a look at the link & see if I can find a aussi group .
cheers neil
ps I hate my Jeep
Good luck,
Let us know if you find a resolution.
