Does WRX rear brake clear 15 inch wheels
mhrallyteam
Post by mhrallyteam »
I have everything to do the swap, but not enough money to buy 16inch wheels and tire right now. So do they clear, i guees so but just to be sure.
By the way i got base model brake, so thats why i'm switching to wrx
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
WRX rear brakes are essentually the exact same rear brakes we have. The only exception to that is if you have an n/a sedan. Then the caliper piston size is 1.374" instead of 1.5".
mhrallyteam
Good, thanks for the answer
josh9227
Post by josh9227 »
wrx breaks did not clear my 15" turbo rim I had to go to a 16" rim
ver 4 STI 300hp VF23....now td04 :-( dam shaft 4.444 spec c trany LTD slip plated diff SOLD
2002 forester S sport 5spd STOCK for now.....
Post by BAC5.2 »
josh9227 wrote:wrx breaks did not clear my 15" turbo rim I had to go to a 16" rim
We are talking about the rear brakes.
The rear brakes are the same diameter as the OEM Legacy turbo brakes, and there's lots of caliper clearence with the stock setup. They should clear without problem.
josh9227
Post by josh9227 »
oh :roll: I dont read things to well its the fronts that dont fit my bad
