EJ22T hybrid Compression question
Imprezive
Post by Imprezive »
My brother is gathering parts to swap some 20G heads onto his 2.2T block. And I know that puts the CR down to 7:1, I was wondering if this was low enough to sort of let the engine "bog down" at low RPM since the turbo won't be producing much boost?
I am guessing the answer is no since people have and are doing this swap. But could someone clear it up for me?
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
professor
Post by professor »
yes it will produce somewhat less power when off boost or when boost is low, due to the lower compression ratio
but this effect is often over-estimated, the function of power versus compression ratio is a weak one
lower compression ratio is a godsend when you have relatively poor engine management, so unless you have a stand-alone, perfectly tuned ecu then you may be better off overall.
historically almost all turbo cars have been between 7:1 and 8:1, with higher compression becoming more common as engine management improves. Most of the outrageous power racing engines of the 80's were in the low 7's.
Matt Monson
Post by Matt Monson »
And the Porshce 930's and 935's of the 70's were around 6.5:1
The EJ22T with Ej20g heads combination is 6.7:1, assuming we are talking about the 89-94 Legacy EJ20G heads. If they are WRX heads, the compression will be marginally higher since the combustion chamber was a little smaller once they went to direct actuation on the valves...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
