28 MPG!?
Manarius
28 MPG!?
Post by Manarius »
4.313 Gallons; 120 miles.
120 / 4.313 = 27.9
Granted, that was not from empty..but 28 MPG!? On a 4EAT? Come on. I wonder why gas mileage gets worse the farther down the tank you go. I usually get 21. Not 28.
Tleg93
Post by Tleg93 »
Are you filling it till you can't fill it any more, running it, then filling to the same spot again? I get around 26 on the highway when I'm not boosting or accelerating real hard.
--Scott--
1991 - Rio Red SS
skid542
Post by skid542 »
I used to get around 31-32 if I wasn't running it too hard. Now I get around 25 but hopefully that'll go back up with the 'new' engine. 21 sounds pretty low to me, esspecially for an NA.
Lee
Manarius
Post by Manarius »
Because my gas gauge doesn't work, I run to about 200-250 miles and then fill up. I consistently get 20-22 mpg. And, I don't drive like a maniac all the time...I hardly drive above 3 grand.
DLC
Post by DLC »
I get 24-26MPG on average, usually 375 miles or more on a 16 gallon tank.
Granted, this is on an NA car with mods, but it is heavier than any 1G Legacy model. Hopefully the Random High-Flow Cat will make it more fuel efficient, powerful and noisy!
Legacy Central
Tleg93
Post by Tleg93 »
You got 31...in a legacy? Wow, I don't think I've ever heard of mileage that good in one of these cars. 21-3 mpg (driving hard to moderate) is what I've gotten in every legacy I've owned. Maybe I've gotten unlucky.
--Scott--
1991 - Rio Red SS
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
I usually get around 19. Hopefully this turbo setup will increase my mileage a little
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
THAWA
Post by THAWA »
I dont see how that's possible Laurel.
A less restrictive exhaust housing could improve volumetric efficiency, which should also improve thermal efficiency.
greg donovan
Post by greg donovan »
creel wrote:You got 31...in a legacy? Wow, I don't think I've ever heard of mileage that good in one of these cars. 21-3 mpg (driving hard to moderate) is what I've gotten in every legacy I've owned. Maybe I've gotten unlucky.
on the hiway in my 95 i can get 30 if i am not too much of a throttle monkey.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
LaureltheQueen
Spelling Nazi
Spelling Nazi
and i won't be in boost all the god damn time
THAWA
Post by THAWA »
You don't have to be on boost all the time, but you'll be making more power right? So won't you fundementally be using more fuel? If you're changing engine management I could see you theoretically being able to get better mileage in some situations though.
That's not necessarily how it works, Hardy. An engine capable of more power isn't always an engine burning more fuel.
I mean, any car makes less power when it's up in the mountains than when it's down at sea level, but it also has worse fuel economy.
LaureltheQueen
Spelling Nazi
Spelling Nazi
It's unlikely that I'll be making more power down low. And I've actually considered setting one of the boost levels at like 5 PSi for cruising around town.
What turbo are you going to use?
Almost any upgrade turbo should make more power off-boost than the stock turbo.
LaureltheQueen
Spelling Nazi
Spelling Nazi
16g TD05.
damn.
Yeah, the TD05H-16G will definitely give you more power off boost. I personally haven't seen an increase in fuel economy because I'm on high boost all the freakin' time, but I do believe Phil and maybe Matt saw mileage improve with the 16G when they drive carefully.
LaureltheQueen
Spelling Nazi
Spelling Nazi
I'm glad.
