Internal baffles in the oil pan?
scottzg
Post by scottzg »
I heard a rumor that the oil pan is seriously baffled. If anyone has a pic of the inside of the oil pan i would love to see it.
jake15
Post by jake15 »
Here is some pics from josh's site
linky
scottzg
Post by scottzg »
courtesy of josh--
THAWA
Post by THAWA »
Baffles are a good thing though, right?
That is a pic of the newer style oil pan. The older pans did not have that lower baffle.
As for, are baffles a good thing, yes they are a good thing. They help keep the oil from sloshing around as much, plus I would assume the lower baffle helps against foaming/cavitation. if you have oil drop/drip from above, it can create air bubbles. That second tray may help provide a "bubble free" area below that the oil pickup tube can suck on.
ballitch
Post by ballitch »
not to venture off topic here, but i read/heard somewhere that the EJ25 pans are a little bit bigger, like a 1/2 quart or something......is this true or just a rumor i heard?
~Josh~
98' Green Sedan EJ22 block, EJ25 sohc heads
86' Tan Wagon w/ EJ22
douglas vincent
Post by douglas vincent »
90 wagon = no baffle
91 wagon = baffle
Subtle
Post by Subtle »
The baffle could spread heat around a little.
Seen the comments on the 90 and 91 , but what does
the 93 turbo have by way of baffles in the sump???
douglas vincent
Just like the above picture, or damned close.
skid542
Post by skid542 »
The 93' NA doesn't have the second baffle. Other than not having the lower baffle, exactly the same. Today when I pulled it off my batteries were dead on the camera, sorry. What's interesting is that the oilpan I pulled off the 'new' engine had an oil pan as shown above.
Lee
douglas vincent
my 93 turbo baffle had the two baffles. Its baffling isnt it?
Subtle
Post by Subtle »
Thanks for clearing up a baffling question, without resorting
to baffleglab.
scottzg
Post by scottzg »
could it have to do with where the pan was made...?
It's kind of a nice feature.
sammydafish
Post by sammydafish »
Legacy777 wrote:That is a pic of the newer style oil pan. The older pans did not have that lower baffle.
My 90 has the lower baffle. Made it a pain in the ass to clean out when I welded by turbo oil return to the pan. Also made it impossable to bang out after I gave it a good crunch launching the scoob a few feet in the air over a ditch :)
- Junior
95L Wagon on T3/T4 boost :)
Not sure what to tell ya. The engine I have is a 94. Unless someone swapped oil pans, it did not come with the lower baffle.
