WRX wheels + 205/55 dont fit my car
tzedek
Post by tzedek »
they rub hardcore on the struts in the back. :(
0perose
Post by 0perose »
that sucks
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Psychoreo
Post by Psychoreo »
i know, i posted the same thing. As a matter of fact, it's three posts down.
stupid electrical work...
tzedek
Post by tzedek »
did you get 205/50 s to work?
Psychoreo
Post by Psychoreo »
my car doesn't work... :( so i haven't swapped for 205/55's yet. but from what i've read, they will fit. they're about 7/8ths of an inch shorter.
dscoobydoo
Post by dscoobydoo »
OK I am curious as to why you guys are having issues.
I am running WRX rims with the stock 205/55/16's on them with no issues.
So my questions to you:
Did you install the struts yourselves?
Were they from another subaru? What parts did you use from your original set -up?
When they were put in, were they "positioned" the right way?
( I ask this in that when I did my rears, they fit two ways. One way they cleared the wheel, the other they did not.)
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Psychoreo
Post by Psychoreo »
what do you mean posisitioned? I may have this issue because i put 02 wrx struts/springs with legacy fwd tops and they hit bad.
jamal
Vendor
Vendor
Post by jamal »
Legacy FWD tops? If it's a FWD car the rear suspension is slightly different, so the WRX stuff probably wouldn't work right. As far as the struts themselves go, I thought the WRX struts will actually give more room between the tire and the perch. There's lost more room between my tires (205/55-16) and my STi perches than there was on stock struts.
tzedek
Post by tzedek »
dscoobydoo wrote:OK I am curious as to why you guys are having issues.
I didnt do the struts myself, I actually just picked the car up.
Psychoreo
Post by Psychoreo »
well then does any one know a way of fixing the set up to accomidate the 205/55's?
dscoobydoo
So what did they put in? I have H&R springs and AGX's and I had no issues when they went in right.
05 GD-STI
00- GF
tzedek
Post by tzedek »
how would I know I just bought the car a week ago.
dscoobydoo
Makes me wonder what they put in. You might end up taking it to a Subaru dealer and have them do a look-see.
05 GD-STI
00- GF
azn2nr
Post by azn2nr »
i just put that tire size on my car. they dont rub but theirs not alot of space back there either. i have a pic ill post later
-jason
jamal
Vendor
Vendor
Post by jamal »
We're going to need to know more about your setup to tell what the problem is.
I didn't have much room on stock struts. I could barely fit a finger between the tire and the perch on the inside:
There's plenty of room with the STi take-offs, though:
Psychoreo
Post by Psychoreo »
i've got stock 02 wrx struts/springs and the stock legacy fwd tops in the rear.
Psychoreo
Post by Psychoreo »
oh yea, and potenza's 205/22/15 on 02 wrx rims with a 53 offset
jamal
Vendor
Vendor
Post by jamal »
I didn't think AWD struts fit on FWD cars. Maybe that's part of the problem?
Psychoreo
Post by Psychoreo »
from my understanding, the fwd and awd struts are the same. it's the tops that are different.
The AWD rear struts most definitely DO NOT fit on FWD spindles.
The mount point on the FWD spindle is inline with the center of the wheel. On the AWD spindle, the mount point is offset from the center of the tire and raised slightly.
The struts are different. You can't mount AWD struts on a FWD spindle......I tried, it doesn't work. You'd have to bend or cut away a portion of the strut bottom.
azn2nr
Post by azn2nr »
Psychoreo wrote:oh yea, and potenza's 205/22/15 on 02 wrx rims with a 53 offset
but you really didnt.
if anythign their 205/55/15
22/15 wouldnt be a wrx wheel and 22 would be a rubberband
-jason
Psychoreo
Post by Psychoreo »
Legacy777 : Is it possible to grind away enough of the bottom to make this possible and still safe?
azn2nr yea...sorry, finger slipped 205/55515
jamal
Vendor
Vendor
Post by jamal »
They're 16" wheels, and no, I don't see how you could grind away anything. The flanges that attach the strut to the spindle are at different angles, so it should be pretty much impossible to install AWD struts on a FWD car and vice-versa.
Psychoreo wrote:Legacy777 : Is it possible to grind away enough of the bottom to make this possible and still safe?
I wouldn't recommend it. It'll probably allow things to fit. However I can't comment on whether the strut body is different or how the perch height changes between FWD & AWD.
Psychoreo
Post by Psychoreo »
well everything fit fine when i had the stock 14 inch rims on it... just now on the 16's they hit
