Cusco type 2 lower arm bar
Parts and services from sanctioned vendors and businesses.
kelley
Vendor
Vendor
Post by kelley »
This chasis brace is like new and im perfect condition.
It is for gc chasis, but fits bc legacy's as well.
$100.00+ shipping
Got a pic? Have you run these bars on the BC chassis to see if it actually adds anything?
kelley
Vendor
Vendor
Post by kelley »
Hey Josh,
I used this on my 94 legacy for a short time, it does make a differance, as there are improvements in rigidity that can be made on a bc.
http://www.i-club.com/forums/showthread.php?t=116718
Legacy777 wrote:Got a pic? Have you run these bars on the BC chassis to see if it actually adds anything?
Damn......just had an alignment....and if I put this on....it'll probably scew things a little.
Looks like you have a tentative buyer on i-club though.
DLC
Post by DLC »
I really liked mine on the BF, it tightened everything up. They also fit the BE, but it hangs much lower for some reason, so I chose not to put one on.
Legacy Central
How much lower does it hang on the BC/BF chassis?
Right now the exhaust is the lowest thing.
DLC
Post by DLC »
It'd probably be close to as low as your exhaust. I can't say that I never hit anything with it, but I know it dragged a bit when driving through snow. Not exactly a problem where you're at.
I don't think I ever got any good pics of what it looked like head-on, but here's my write-up:
http://legacycentral.org/library/cusco_lower.htm
Legacy Central
kelley
Vendor
Vendor
Post by kelley »
Clearance was never an issue for me, and my car sat about 1.5-2 inches lower than stock
but I'm not the type of driver that drives fast in to driveways and such.
Legacy777 wrote:How much lower does it hang on the BC/BF chassis?
Damn...it's very tempting....
kelley, let me know if you don't sell it to the guy on i-club.
kelley
Vendor
Vendor
Post by kelley »
Legacy777 wrote:Damn...it's very tempting....
Still available!
ej22t
Post by ej22t »
Its a good bar that I have in my 92 turbo, it only fits with turbo crossmember, I got it from my friend who had order for his 98 2.5RS but when he try to install that he find out it won't fits and it only fits all turbo from 91-01 Legacy and WRX only.
It is very light weight and its good low chass upgrade.
Good luck
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
THAWA
Post by THAWA »
Legacy777 wrote:Damn......just had an alignment....and if I put this on....it'll probably scew things a little.
Why? You're not moving anything that affects the alignment.
I suppose so.....you'll get a little change in the bolts, but it shouldn't be too much to matter
Still available!
pm'd ya.
dscoobydoo
Post by dscoobydoo »
Highly recommended. I have one and between that and the FSTB the front end is very tight!
Free bump!
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
kelley
Vendor
Vendor
Post by kelley »
pm sent!
kelley
Vendor
Vendor
Post by kelley »
SOLD!
