atf temp guage
atf temp guage
is there anyb reason why you couldn't use a noraml temp guage on the auto fluid?
i have set one up and all is go but she won't measure the temp
just put a tee peice into the cooler lines for the sender unit
any help would be good
cheers
cheers
What's a "normal" temperature gauge? If you're asking whether or not any old oil temp gauge would work, I think it would. You just need to make sure the sender unit (if it's electrical) or the gauge mechanical parts (if it's mechanical) is oil-safe. So you probably wouldn't want to use any old water temperature gauge.
When you say it won't measure the temp, do you mean it just reads a certain value all the time? What kind of gauge is it?
yep got power, got an earth. have an oil pressure guage set up next to it exactly the same, works fine. tried another guage in case it was faulty, still no go.
guage has 3 connections. power, earth & sender. no leaks at the sender the atf should heat up same as engine coolant( ?) so tyhe guage should show failry quick hey. who knows, looks good in the dash though!!!
- Spelling Nazi
Ooh, just one wire for the sender? The sender grounds through its body, then, no? Do you have the sender in a place where its body can ground through the chassis? The ATF cooler lines may not actually be grounded well enough. You may need to run a ground wire to the sender body itself somehow.dagsy wrote:guage has 3 connections. power, earth & sender.
Every 1-wire temperature sender I've seen was basically just a thermistor. One terminal of the thermistor was connected to the wire or connector on it and the other to its body.
Think about it -- you can't send a signal with just one wire.
So, yeah, try attaching a wire to the sender with a hose clamp or something and running it to a good convenient ground, like maybe a bolt on the intake manifold.
tried grounding the sender to both body and engine, but that just open circuits the guage giving it full voltage.
the oil pressure guage is set up exactly the same way and it works a treat
tried using a pot of boiling water to get a reading and still no luck
if only it came with fitting instructions
Hehehe... Yeah, you need to ground its body. Normally it expects to be threaded into the transmission itself, so its body is connected to the chassis that way. Leave the one-wire connector going straight to the gauge.
well, i think it will be new front sway bar with hd links. just put on an 18-22 on the rear and it feels heaps nicer. being a wgn it got a little roll on around corners, now it seems to sit nice and flat.
iv'e heard you shouldn't have a bigger bar on the rear than the front (?) so that will be about it.
