Yeah 400 miles from home with a full load of people and board gear it dies. Good thing our motors have enough power to get around without getting into boost.
I dont know if the air flow sensor is dead, i think that code was thrown because i disconnected it and then tried to start the car.
I tested the pressure exchange solenoid valve and it still clicks.
the pressure sensor is 321.51 at subaruparts.com anybody have a cheaper source for one?
pressure sensor and air flow sensor died.
biggreen96
I don't think the EJ22T ECU can run without a functional MAF sensor, so that's probably okay.
Are you sure the pressure sensor failed? It might be an electrical problem or a problem with a hose.
If you do need to replace it, here's a cheaper option:
http://www.graphics.cornell.edu/~v/chrysler_map/
So what happened to the AVC-R?
The CEL for the MAF would be because you did unplug it. I remember getting some codes years ago because I was unplugging injectors to make sure everything was working right, but they were just stored until cleared.
Legacy Central
biggreen96
Avc-r is still kicking, thats how i could get home without bumping into fuel cut at ~ 25% throttle. the avc-r has its own pressure sensor though right?
the hoses looked okay when i was poking around. although its time for all new vacuum line in the engine bay, ill do that very soon.
biggreen96
Update:
it was in fact a dead pressure sensor.
went out tonight and hooked the new one up (281 shipped @ SubaruParts4you.com) ran some new vac line around and she runs like a champ again.
free5ty1e
Yikes! You mean you didn't see Vikash's writeup on using much cheaper domestic pressure sensors to replace a faulty Subaru sensor?biggreen96 wrote:Update: (281 shipped @ SubaruParts4you.com)
-Chris
91SS 4EAT stock, 200k mi
Gah. Well, at least that fixed it
Legacy Central
biggreen96
