ej22t head gaskets fit ej25 stuff.
ej22 head gaskets ONLY fit 2.2 NA, I don't know if this is true past 1994. So if you want to mate NA heads to ej22t block, you need to drill out the head on the upper water jacket area, or drill out the head gasket.
Head gaskets, which fit which? Here is some info.
douglas vincent
