starting problem
starting problem
Hi,i had an od problem,car was working normaly,and it was stand still about two weeks,then i started and give extra power to other car with cabels,and my legacy shut down and wont start.. after littlebit inspecting, it did wet the s-plugs. (Iridium spark plugs) then we pulled it for many km`s and it did start but it was running badly. then next week i tryet,and it wount start again,only wets s-plugs again... could it be camshaft sensor fault? and is iridiums sensitive of getting wet. i have heard that thous wont works probely after get wet...
Legacy 200
Do you have any NGK copper spark plugs to try? If not, you should probably buy some. There's a sticky post about this somewheres...
-Chris
91SS 4EAT stock, 200k mi
