Anyone here tried Megasquirt?
IronMonkeyL255
Post by IronMonkeyL255 »
I was debating going with a standalone EM system, and this looks to be a very affordable option.
I just had a few questions about it:
Can the MS-I control spark as well as fuel? In the description, it says fuel control, but in the specifics, it mentions use of ignition coil triggering and an onboard direct ignition coil driver. The MS-II description says specifically fuel and ignition. It's a $60 difference, so if the -I can do what I want it to, that'd be awesome.
Would this completely eliminate the need for the stock ECU? If so, would it mess with my auto tranny any? Isn't there some data sharing between the ECU and the TCU?
Rio Red '91 Legacy SS
Splinter
Post by Splinter »
At the moment, MegaSquirt actually can be a bit more versatile MegaSquirt-II because of the firmware. In particular, the "MegaSquirt-n-Spark-Extra" firmware can do a kajillion different things including various types of spark control. MegaSquirt-II has much much more potential though.
None of the spark control mechanisms works directly with what we've got, but you could just adapt a Ford EDIS system to your engine and then use either MegaSquirt's ignition setup.
You do also need to add an intake temperature sensor.
The stock coolant temperature sensor can be made to work with the appropriate modifications to the lookup table in MegaSquirt, and the electrical modification if the stock ECU still shares it.
The TPS motion is reversed as compared to what MegaSquirt likes. If the stock ECU is still around, you'll either have to condition the signal (look for a post I made about doing this for the Perfect Power) or modify the code (which isn't hard).
With some hacking, MegaSquirt or MegaSquirt-II can replace the stock ECU, but it might be easier to leave it so it can continue to control idle and the radiator fans and the air conditioning compressor and whatnot.
Read up at:
http://www.megasquirt.info/
http://www.msefi.com/
http://megasquirt.sourceforge.net/extra/
Oh, sorry, I forgot you had asked about an automatic.
The TCU basically just needs a TPS signal and a tach signal. I believe EDIS would supply a usable tach signal, which you'll want for your actual tachometer anyway, and you'll have to leave your stock TPS wiring alone.
IronMonkeyL255
So you mean I could get something like this to work:
Brand: Accel
Product Line: Accel Ford 4-Tower Style EDIS Super Coil Packs
Coil Wire Attachment: Female/Socket
Coil Style: Coil pack
Coil Internal Construction: Epoxy
Maximum Voltage: 42,000
Turns Ratio: 85:1
Primary Resistance: 0.500 ohms
Secondary Resistance: 11.6K ohms
Mounting Bracket Included: No
Coil Wire Included: No
Ballast Resistor Included: No
Coil Color: Black/Yellow
Coil Shape: Square
Quantity: Sold individually.
Would I just have to hook that up, or would I need their version of our igniter?
IronMonkeyL255
Okay.
After a bit more looking around, I figure I need an EDIS-4 control module. I may be able to get away with using the stock ignition coil, which would be awesome.
The main thing I am wondering about is how to get the VR signal for the unit without retrofitting a 36-1 wheel to the crank. Would there be a way to use or modify the stock crank angle sensor to give what it is looking for?
You can use that coil pack, but, yes, you need the EDIS control module. The stock coil pack may or may not work.
You need to use the EDIS wheel. It's not that big a deal to fit it to the stock crankshaft pulley and then make a bracket to hold the pickup in the right position (a stock Subaru cam or crank sensor pickup would actually be a good choice).
IronMonkeyL255
Hmmm.......
Main thing is, it looks like with alot more work, you can get it to work with the stock components.
I may have to look into the EDIS setup, though, as it looks to be much better documented.
IronMonkeyL255
Also, playing with MegaTune, there is some pretty cool stuff in here.
It has a TPS calibrator built in, along with traction control and boost control in the MSnS-E firmware.
Yes, in principle there's no reason you couldn't make it work without adding things under the hood. After all, the stock ECU does.
Yeah, MSnS-E has a kajillion features and they're adding them all the time (although they're starting to hit the limits). Many aren't very well-tested, but they're there, and waiting for someone (someone like you!) to do it. :)
IronMonkeyL255
I may try this if I could get some help from you and the others doing tuning on our engines.
Honestly, I would prefer to get it to work with the stock ignition setup. I noticed, it also has a wheel decoder for the VR sensor/coil control. So theoretically, I could at least get the crank sensor working.
I'm probably not going to use alot of these features, but it's nice to know they're there. I may get adventurous and try water injection later, but I'm never going to try nitrous and will probably have no need for launch control.
Are our injectors low or high impedence? I'm assuming low, but want to make sure.
There's actually already a dual-wheel decoder in MSnS-E, too. It's for the Neon engine's cam and crank sensors. I don't know how big a leap it would be to go from there to ours in the framework laid out by the existing code.
Our injectors are high-impedance.
Honestly, I think you'll get more help on the MegaSquirt forums than here on tuning. In principle it's not that hard though...
IronMonkeyL255
Main thing is I want to find out how to get it in and running in our cars, and I think there will be a bit more info regarding our vehicles here.
I do plan on going over to the MS forums as well, but will probably wait until closer to the date of implementation.
I plan on getting it a basic setup, then going to get it professionally tuned. There's a tuner down in ATL that really know his stuff, and has worked with MS before.
Cool. I'll help you figure stuff out. It's all pretty simple.
The TPS signal will have to be conditioned with the circuit described here:
http://bbs.legacycentral.org/viewtopic. ... 495#150495
To get it started running as a fuel-only piggyback, I think you should be able to take a tach signal from the two ignition control channels, using diodes to combine their signals. Connect an anode to each ignition channel and the cathodes together to MegaSquirt's tach input.
This thermfactor.inc file should be correct for the stock Subaru coolant temperature sensor:
Code: Select all
THERMFACTOR:
	DB	210T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	255T
	DB	252T
	DB	248T
	DB	245T
	DB	243T
	DB	239T
	DB	238T
	DB	234T
	DB	232T
	DB	229T
	DB	227T
	DB	225T
	DB	223T
	DB	221T
	DB	220T
	DB	218T
	DB	216T
	DB	214T
	DB	212T
	DB	211T
	DB	209T
	DB	207T
	DB	205T
	DB	203T
	DB	202T
	DB	200T
	DB	198T
	DB	196T
	DB	194T
	DB	193T
	DB	193T
	DB	191T
	DB	189T
	DB	187T
	DB	187T
	DB	185T
	DB	184T
	DB	184T
	DB	182T
	DB	180T
	DB	180T
	DB	178T
	DB	178T
	DB	176T
	DB	175T
	DB	175T
	DB	173T
	DB	171T
	DB	171T
	DB	169T
	DB	169T
	DB	167T
	DB	167T
	DB	166T
	DB	166T
	DB	164T
	DB	164T
	DB	162T
	DB	162T
	DB	160T
	DB	160T
	DB	158T
	DB	158T
	DB	157T
	DB	157T
	DB	155T
	DB	155T
	DB	153T
	DB	153T
	DB	151T
	DB	151T
	DB	149T
	DB	149T
	DB	148T
	DB	148T
	DB	146T
	DB	146T
	DB	144T
	DB	144T
	DB	142T
	DB	142T
	DB	140T
	DB	140T
	DB	139T
	DB	139T
	DB	137T
	DB	137T
	DB	137T
	DB	135T
	DB	135T
	DB	135T
	DB	133T
	DB	133T
	DB	133T
	DB	131T
	DB	130T
	DB	130T
	DB	128T
	DB	128T
	DB	126T
	DB	126T
	DB	124T
	DB	124T
	DB	124T
	DB	122T
	DB	122T
	DB	122T
	DB	121T
	DB	121T
	DB	119T
	DB	119T
	DB	119T
	DB	117T
	DB	117T
	DB	117T
	DB	115T
	DB	115T
	DB	113T
	DB	113T
	DB	113T
	DB	112T
	DB	112T
	DB	112T
	DB	110T
	DB	110T
	DB	108T
	DB	108T
	DB	108T
	DB	106T
	DB	106T
	DB	106T
	DB	104T
	DB	104T
	DB	103T
	DB	103T
	DB	101T
	DB	101T
	DB	 99T
	DB	 99T
	DB	 97T
	DB	 97T
	DB	 95T
	DB	 95T
	DB	 95T
	DB	 94T
	DB	 94T
	DB	 94T
	DB	 92T
	DB	 92T
	DB	 90T
	DB	 90T
	DB	 90T
	DB	 88T
	DB	 88T
	DB	 88T
	DB	 86T
	DB	 86T
	DB	 85T
	DB	 85T
	DB	 83T
	DB	 83T
	DB	 81T
	DB	 81T
	DB	 79T
	DB	 79T
	DB	 77T
	DB	 77T
	DB	 77T
	DB	 76T
	DB	 76T
	DB	 76T
	DB	 74T
	DB	 74T
	DB	 72T
	DB	 72T
	DB	 70T
	DB	 70T
	DB	 68T
	DB	 68T
	DB	 67T
	DB	 67T
	DB	 65T
	DB	 65T
	DB	 63T
	DB	 63T
	DB	 61T
	DB	 61T
	DB	 59T
	DB	 58T
	DB	 58T
	DB	 56T
	DB	 54T
	DB	 54T
	DB	 52T
	DB	 52T
	DB	 50T
	DB	 49T
	DB	 49T
	DB	 47T
	DB	 45T
	DB	 45T
	DB	 43T
	DB	 43T
	DB	 41T
	DB	 40T
	DB	 38T
	DB	 36T
	DB	 34T
	DB	 32T
	DB	 31T
	DB	 31T
	DB	 29T
	DB	 27T
	DB	 25T
	DB	 23T
	DB	 22T
	DB	 20T
	DB	 18T
	DB	 16T
	DB	 13T
	DB	  9T
	DB	  7T
	DB	  4T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	  0T
	DB	210T
IronMonkeyL255
Sweet.
By doing that to the tach signal, you mean F47.9 and F47.10?
How would you suggest doing that as a fuel/spark system?
Yes, that's what I mean.
If you're also running spark with EDIS, then you get the tach signal for the tachometer and TCU from the PIP or IDM line of the EDIS unit. I think they're directly compatible. If not, we'll have to think of something.
IronMonkeyL255
I was noticing that on the latest versions of the MSnS-E firmware, they have an option for tachometer output.
Talking to one of the guys on Nasioc who is using MS-II in his EJ22E swap into his '88 RX, it looks like our cars use a 6/7 wheel for crank angle, while the EJ205 and EJ257 use a 36-2 wheel. They are supposedly releasing a MS-II version 3 that will support both of these.
I'm gonna try to get more info, but this looks like a good thing to wait for.
Bheinen74
uh huh huh Megasquirt, loaughing at that name....
Post by Bheinen74 »
just had to make fun of that name, sounds like the name for a porno star or ??? something worse.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
IronMonkeyL255
Did I mention that while assembling it, you use the Megasquirt Stimulator?
Just another funny thing.
Will, the other guy putting this on an EJ22 was going to be writing most of the reference files from scratch, so I'll see if I can get my hands on that once he's done.
Wouldn't it be possible for someone to write the code to read the Subaru cam and crank triggers? I'm shying away from the MS because I have enough ahead of me to get my car going.
So, anyone interested in a MegaSquirt II Ver. 3? I have one sitting here assembled, tested, jumpered for VR, and loaded with MSnS-E and all that.
IronMonkeyL255
how much?
devej22
Post by devej22 »
Hey guys, I'm new hear but have some experiance with Megasquirt unfortunatly not with Subarus but its pretty much similar where ever you try to install it. MS is very simple yet very powerful. Couldnt be easier to install (i had fuel only on a BMW 528i). Piss easy to tune (take many datalogs and use Megatune and MSTweak to calculate a new VE table according to the Oxy sensor reading)
If you are going to do your own tuning a WIDEBAND OXY SENSOR IS A MUST!!! Its worth alittle more then the ecu itself but it's an invaluable tuning tool. I highly recommend the Innovate Motorsports LC-1 (no affiliation)
http://www.innovatemotorsports.com/products/lc1.php
I have done little in the way of tuning ignition but shouldnt be to hard. MS is constantly being updated and MSII would be the way to go simply because of the higher potential.
I have learnt heaps by reading and thats what i suggest you do. It is well worth it and can be a challenge at times. A piggyback set up would cause less in the way of headaches but might prove more challenging to make both ecus share the sensors, very doable though.
Any questions just ask! :-D
