Headlights dim near redline
Splinter
Post by Splinter »
Not that its annoying, it happens so rarely and for such a short amount of time that it took me a few tries to make sure it was actually happening
Just wondering if its a symptom of some other problem
Basically, in the half second or second between 6000rpm and the AT gear change (when forcing high changes by leaving the selector in 1 or 2), the headlights dim to about half voltage
Bheinen74
Post by Bheinen74 »
might be yer alternator belt slipping when the pulley is turning at fast RPM....
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Post by BAC5.2 »
I second that. Check alternator belt tension.
My ALT belt was slipping bad, and under load the lights would dim.
Check that and see.
jnorion
Post by jnorion »
Wouldn't you hear that squealing as it slipped, though?
~Joel
0perose
Post by 0perose »
jnorion wrote:Wouldn't you hear that squealing as it slipped, though?
not necessarily... if you're at redline with throaty exhaust and that "boxer growl" we all love so much
yo mang, can I get a rootshell?
1991 N/A, 4eat, crazy lights, junk suspension, sticker wagon
1989 xt6 work in progress
Bheinen74
Post by Bheinen74 »
if your belt is old, it will be glazed, ie slick and it will slip and not be noisy.
get a new alt. belt, and proper tension. cheap fix.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Splinter
Post by Splinter »
I probably just didnt tension it right after I did the alt swap
How do I properly set the tension?
realfinn
Post by realfinn »
If you find that its not the belt check the ground for the headlight. During High RPM you are requiring a lot of juice. If the ground is getting bad you might not be flowing enough for the headlights all the time. This can happen inconsistantly, wouldn't have to be every time you run the engine hard.
