Moderators: Helpinators , Moderators
bmxkelowna
Posts: 1047 Joined: Thu Feb 16, 2006 5:00 am
Post
by bmxkelowna » Fri Mar 10, 2006 7:59 am
i have tryed taking off the 4 little gold nuts (8mm) and getting the tail light out but it would not budge. is there any thing else i have to take off to get it out?
Kelly
Posts: 1286 Joined: Sat Nov 01, 2003 5:35 pm
Post
by Kelly » Fri Mar 10, 2006 8:27 am
Heat.
Its pretty much glued in there with butyl.
Heat the peremater from the inside with a hair dryer, and you'll loosen it up a bit.
Pull.
bmxkelowna
Post
by bmxkelowna » Fri Mar 10, 2006 8:30 am
oh really?
odd lol
okay ill try that
then when i put it back in, just the 4 nuts?
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Fri Mar 10, 2006 3:09 pm
If the adhesive's still gooey and clean, then it'll stick itself back together when you push the taillamp back in.
If it's not, just use some windshield-setting tape or caulk.
LaureltheQueen
Spelling Nazi
Posts: 4644 Joined: Fri Aug 29, 2003 7:14 am
Post
by LaureltheQueen » Fri Mar 10, 2006 4:23 pm
*perimeter
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
Post
by vrg3 » Fri Mar 10, 2006 4:28 pm
"I was just doing a 'parameter check.'"
know1
Posts: 520 Joined: Thu Jan 18, 2007 9:28 am
Post
by know1 » Fri Apr 20, 2007 10:06 am
*bump*
I am going to be doing this soon. What kind of caulk should i use? Or better yet, is there a product name for windshield tape?
stipro
Posts: 699 Joined: Mon Apr 26, 2004 4:20 am
Post
by stipro » Fri Apr 20, 2007 6:36 pm
know1 wrote: *bump*
Its called butyl tape. If you go to a windshield replacement center, a smaller company perferably, they may even give it to you for free
n2x4
Posts: 1522 Joined: Tue Oct 18, 2005 3:52 pm
Post
by n2x4 » Fri Apr 20, 2007 6:47 pm
I've yanked my taillight twice and just reuse the old stuff. They really put it on, and it hasn't leaked since I've reused it.
Just press it on really tight, that stuff sticks.
SUBARUEHS Racing
IronMonkeyL255
Posts: 1902 Joined: Sat Aug 09, 2003 5:02 pm
Post
by IronMonkeyL255 » Fri Apr 20, 2007 8:16 pm
If you do need some fresh stuff, 3M Windoweld is what I used. Comes as a roll in a box. I got it from my local Advance Auto Parts store.
Rio Red '91 Legacy SS
SP-Boxer
Posts: 223 Joined: Tue Feb 28, 2006 4:22 pm
Post
by SP-Boxer » Fri Apr 27, 2007 10:26 am
I also used th 3M stuff. Works perfectly!
"I feel Legacy"
