Destroked EJ25
Destroked EJ25
Unless anyone can come up with a good reason not to..... I am building up a phase one EJ25 block with the crank and rods out of a EJ22t. This will effectively destroke the EJ25. This looked to, in the mock up to be a really cheap way for me to build a turbo motor for my outback. I will only need to pick up some rings and perhaps a set of main bearings. I will be using the dished EJ25 piston, and the thicker headgasket, as well as the DOHC heads.
The only detractors I can think of is oil squirters (easily fixed), and the open deck (I only plan on running around 14LBS).
- quasi-mod-o
Isn't crank throw the same, but rod length is different.
Running EJ22T rods will give you, roughly, the EJ22T setup but with open deck. 8.0:1, 14psi, open deck... The WRX does it. I don't see why it wouldn't work for you.
Are you confident of this compression number? What heads / version of pistons NA dished phase 1, or NA flat top phase 2 / and headgaskets did you factor in to come to this compression ratio? This is pretty much what I was shooting for.BAC5.2 wrote: Running EJ22T rods will give you, roughly, the EJ22T setup but with open deck. 8.0:1, 14psi, open deck... The WRX does it. I don't see why it wouldn't work for you.
After the mock up it sure looks like it should work great.
you want this:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
In order to stroke the 2.2 w/2.5 crank you must use custom pistons to keep the deck height correct.206er wrote:if you can use a ej25 crank to stroke an ej22, than no, the cranks do not have the same throw.
the deck height is the same however, which is why the ej25 rods are shorter.
The stroke is 4mm longer or 2mm up in the bore and the 2.5 rods are only 1mm shorter.
Eric
- quasi-mod-o
I've talked to a few guys who are looking at doing this, but can't claim to have any personal knowledge about how it would work...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
