FCD install help
FCD install help
I am wondering if anyone has pics of an installed FCD so I know what wires to splice into. This is gonna go on a '94 SS.
If you cant decipher the text instructions, with the ECU pinouts......you cant install the FCD....having said that. A picture wont help you the wires are so crowded you wouldnt be able to tell, which went where. Search the VRG3 FCD and find the instructions, and the ECU pinouts, then go at it...its cake.
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
