hi
Well im in the game now cuz i just bought a 1991 legacy ss with a blown motor, i think it spun a rod bearing. The JDM the im buying for five hundred dollers (ej22t) has a lot of thing on it already like the turbo heads and other things, but im wondering what i should relpace while the motor is out, i only have five hundred dollers to spend on other parts so can u give me some ideas besides spark plugs, plug wires and an oil filter.
thanks,
Jason
motor swap
The jdm version of the turbo motor is a ej20g. The usdm was the only one that got the ej22t. Anyway, while its out you should probably replace the oil pump o-ring, the front main seal and the water pump at least. It should be good for quite a while with those things done. Then just change the oil at the regularly scheduled intervals and you should be good.
Oh yeah, where are you from?
*edit*
also see this thread.
http://bbs.legacycentral.org/viewtopic.php?t=26628
You will be able to find a lot of information if you do a search for it.
*edit*
///M
'93 Legacy SS - part out
O i just thought that because the guy thats getting the motor for me said that it was a JDM ej22t motor so i geuss he was just wrong about the JDM part o well it doesent matter anyway. My name is jason i live in Vancouver,WA. So what kinda of subie do you drive. Also what are normal performance upgrades that SS owners do after they have a STI top mount, full STI suspension swap, STI short shifter, stage lll clutch kit, and gretty tpye r BOV? cuz thats pretty much all i have im just looking for more.
Project_Legacy
Project_Legacy
