Doors intermittantly not locking
I had an issue recently where my front passenger door would not lock when I locked it. The button would start to lock, and then bounce back. If I unlocked & locked the doors again, it worked fine.
Other thing to note is that I have noticed a slightly weird rattle in that same front passenger door when I closed it. Didn't really think much of it at the time.
I took the panel off, and found that the rod going up to the door lock assembly had popped off. This was causing the rattle I heard, and more then likely was impeding the button from locking at random times.
I guess I would have figured this out if I ever would have unlocked the door from the passenger side, but I don't think I've done that for years....hahaha :lol:
thefultonhow
Post by thefultonhow »
Mine was also not locking for a short time. I opened the door and worked the latch back and forth with a pencil and it fixed it.
Sometimes it's the easy stuff... :)
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
