Hey guys. Getting ready to dump in the EJ22T into the legacy. I have been looking for a cheap option on engine mounts..the guy I bought the engine from had cut the engine mounts in half to seperate the engine from the crossmemeber (must be the hack saw was closer than the wrench). I haven't had much luck finding anything cheap and readily available. Then I checked out the mounts on my EJ22 NA which appear to have been replaced recently (just bought the car). Can I use the NA mounts on the Turbo engine? It would make life a lot easier....not to mention cheaper. Not sure if the durometer of the rubber is the same.
I plan on pulling the engine next summer for a full build up...then I'll probably install group N mounts. But for now I want to just get her runnin'.
Thanks!
EJ22T Engine mounts - Same as EJ22 NA?
greg donovan
