Increasing Fuel Pressure 7psi?
napphappy
Post by napphappy »
What do you think would be the results of increasing fuel pressure by 7.1psi?
I ask because that is the increase if you run a STi FPR. And I consider runing one becuase, they can be had cheap, and they have a hose barb in and out, which is nice for running parallel fuel rails.
douglas vincent
Post by douglas vincent »
Worse milage for one, but maybe not that worse.
Yeah, worse mileage, and probably less power, unless you tune things. I don't know the percentage on how much 7.1 psi gives you in terms of flow....or if it's in the range that the stock ECU can compensate for.
