tranny swap
Arturo
tranny swap
Post by Arturo »
is it posible to put a legacy 95 and up transmission on a 90-94 legacy i know mechanicaly it will fit but what about the speed sensor and electrical connectors.
Suby tech on the way
206er
Post by 206er »
an at or mt? IIRC the at will be pretty difficult to swap because of different wiring setup, but the MT should be easy.
Again....AT or MT......
If AT, I believe you could use the phase 1 4EAT, but would have a hard time getting the phase 2 to work.
I believe the phase 1 4EAT was in the legacy until 96 or so.
As for the speed sensors, you can take out the electronic one and put in the mechanical I believe.
Arturo
Post by Arturo »
its a AT tranny is from a fwd legacy that a friend has in his house and i wanted to put it on another friend's legacy wagon.
