SO! The swap is done, and i swapped out the Cruise Computer (92 AT computer ---> 90 MT computer) and swapped the Relay and wired in the change to the plug:
AT-------MT
1 ------> 2
2 ------> -
3 ------> 3
4 ------> 4
----------- 1 -----> Switch on Clutch pedal -------> Ground
I DON'T know if the MT donor had working cruise control.
I DON'T know if the AT wagon had working cruise control.
I am not getting any light on my cruise switch. Thought it might be the bulb in the switch, went for a ride, engaged it, set the cruise (above 45 mph).... nothing.
I thought of a couple of things that might be the problem....
I need to check for continuity on both the clutch and brake pedal switches.
I need to know HOW to test the neutral switch in the manual
transmission. Is there continuity in neutral or continuity in gear? I didn't get continuity in either position leading me to guess the neutral switch in the transmission is bad. If that neutral switch is bad AND we are getting an "open" signal from the transmission, will that open signal deactivate the cruise control?
Where is the neutral switch?
How do you change it out?
How do you test it?
I also thought of the relay being bad. Is there a way we can test that relay?
How about that momentary switch on the dash board. How is that tested?
I know the cruise control problem is minor, just need a few nudges in the right direction. Thanks!
5MT Swap Cruise Control Question.....
