1 - go to the junkyard
2- pull an intake manifold off and salvage the hard fuel lines and injector bosses. Cut off a few injector clips. LEAVE THE INJECTORS. The junk yard may want to charge you for them.....
3- find the scrap fuel pump and yank it.
4 - go home
5 - buy a gallon of denatured alchohol and 2 gallon bucket
6- hook up the fuel pump to a battery, the hard fuel line, and route the return to 2 gallon bucket. The pump MUST be wired correctly. If you are hearing the pump work, but no fuel coming out the hose, SWAP THE - and + wires.
7 - wire the pump to a spare battery. Make sure it works.
8- wire up the injector clip (s) to longer wires so you can attach them to the battery to turn them on.
9- turn pump on and one injector.
10- BINGO, you are now running alchohol through your injector at a 100% duty cycle!
11- You WILL be able to see if your injectors are clogged or not. Its pretty obvious because a clean injector sprays so perfectly.....Check alll your injectors against each other.
12- to measure flow rate, simply run each injector for 15 seconds into a receptacle 3 time and average the amount. Measure the amount and multiple by 4. Thats your flow rate. Obviously you need a CC reading receptacle.
Have fun!
How to clean and flow test your injectors for about $40
douglas vincent
Last edited by douglas vincent on Tue Aug 08, 2006 7:58 pm, edited 1 time in total.
theflystyle
One Heads up:
I have done this before, Just DONT use rails or lines that smell like varnish AT ALL.
I used the same set up(except I used Injector cleaner) and everything worked fine, for a couple minutes. Then #4, the last one before the FPR, started to slowly flow less and less untill it was just a drip.
Turns out, the cleaner started to dissolve the varnished gas that was in the lines, and it completly clogged the screen on the injector.
So I ended up taking them to a local shop and had them flow tested.
