Whats goes in this hole in my dash?
I was trying to figure out what alarm came with with my car so I took off the lower part of the dash. Noticed the panel below is empty. What feature/device is suppose to go in there?
'11 WRX Limited
'94 TW | R.I.P.
free5ty1e
My 91 has the coin tray, marked Tray and with an easy-open handle.
My 92 and 94 both have the plain plastic panel there, it can be popped off pretty easily by hand.. and makes a pretty inconspicuous hiding place.
-Chris
91SS 4EAT stock, 200k mi
free5ty1e
I also found it was a good place to extend the check connectors into... to flash engine codes all I have to do is pop the cover and connect 'em up, instead of having to remove that piece. I lengthened the wires enough so that the panel can be dropped to the floor safely.
Of course, I've since installed a parallel connector and power for my car laptop to run Vikash's select monitor software, so I haven't needed to flash any engine codes...
I didn't realize it was an interior color thing and not a model year thing, that's strange.
-Chris
To answer the original question.
On 92-94's I do believe that is where there is a bit of ABS stuff. Not a coin tray. Or atleast my blue interiored 93' L (with no ABS) didn't have a coin tray and just had the cover. Somewhere around on it there is something stamped ABS if I recall correctly.
Lee
It's stamped "ABS" because it's made out of ABS plastic.skid542 wrote:To answer the original question.
'93 Touring Wagon
- quasi-mod-o
thefultonhow
I thought that was the airbag control module?subyluvr2212 wrote:The ABS models have the control module right under the stereo, ahead of the shifter. It sticks out of the dash, unlike the non-ABS models that have a recess in that area.
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
IronMonkeyL255
ABS control module is located under the front passenger seat.
Rio Red '91 Legacy SS
