code 44
91l-t
code 44
Post by 91l-t »
I recently did a turbo conversion on mt 91l compllete harness and everything I'm getting a code 44, car falls on its face under load.... any ideas?
91 legacy l blue ej22t
92 ss auto (wife's)
97 outback ej20 13.7 @ 97mph :)
91l-t
Post by 91l-t »
nobody has had this problem?
92 ss auto (wife's)
What are you using to control boost?
You need to have the wastegate solenoid installed, or you need to put one of those transmission dropping resistors in the connector so the code will go away.
91l-t
Post by 91l-t »
thanks, but I figured it out yesterday one wire wasn't seated properly at the ecu. runs great now.
92 ss auto (wife's)
cool
