93 legacy have illuminated hazard button?
Just wondering, because i might change the bulb if there is one, because i thoought there was , for some reason i thought there was, but can someone confirm this? Thanks
Eric.
Bheinen74
Post by Bheinen74 »
yeah, its suppose to be lighted. on my 92 and 94 its burned out, but my 93 still lights up.
time to get the the junkyard for bulbs, and i need bulbs for the illumination on my cruise, defrost switxh too.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Bheinen74 wrote:yeah, its suppose to be lighted. on my 92 and 94 its burned out, but my 93 still lights up.
really? OMG im not crazy, you know what im talking about right? the little button above the vents in the middle with the triangle, just making sure.
Ya i got to do the cruise and def buttons to, and the radio.
Bheinen74
Post by Bheinen74 »
yep. a couple months ago, i had my cruise/def switch out, and was messing around with it. just the bulbs are replaceable (at least on the cruise/def), they are VERY tiny bulbs. if you take apart the switch, you will see how the bulbs actually have a mounting base that threads into the side of the switch, very very tiny things.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Bheinen74
Post by Bheinen74 »
its kinda hard to find the switches at night when its dark, and the illumination bulb is burned out.
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Legacy777 wrote:search is your friend ;)
http://bbs.legacycentral.org/viewtopic. ... io%2A+bulb
oops thanks legacy, close the thread if you want.
