Now What! !!!!!!!!! part 2
Hmmm, It is still doing it. The last time it went back to normal
within 10 minutes of driving. What could have gone wrong? No "Check
Engine" light.
The way it is acting I am beginning to think it may be the wastegate,
it goes up to 5-1/2psi then pulls it back to just under 5psi. In
other words it is acting perfectly normal with the exception of the
actual boost pressure.
PLEASE help guys, I have to drive 6-1/2 hours up to Saugatuk MI on
Friday to run a TSD Rally!
PeteH
-------------------------- eGroups Sponsor -------------------------~-~>
eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9699/2/_/_/_/972182956/
---------------------------------------------------------------------_->
Engine" light.
PeteH
eLerts
It could be that your factory boost solenoid is failing.
A Hallman would be the cheapest way to replace it with an adjustable
setting and it works really good on mine, though i'm going to get an
AVC-R very soon.
If you have no vacuum leaks, no CELs and are still getting decent gas
mileage and don't seem to be running rich, i'd think it's something
in the wastegate too.
--- In BC-BFLegacyWorks@egroups.com, "Pete Harjung aka: PeteH"
No "Check
> Engine" light.
wastegate,
> PeteH
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972183823/
AVC-R very soon.
No "Check
> Engine" light.
wastegate,
> PeteH
eGroups eLerts
Pete, did you try and reset the computer at all? If for whatever reason the
ECU sees a problem(such as detonation), it will open the wastegate early. If
you reset the computer and your boost returns, I'd do as Dave said and grab
a Hallman.
-Matt
-----Original Message-----
To: BC-BFLegacyWorks@egroups.com <BC-BFLegacyWorks@egroups.com>
Date: Saturday, October 21, 2000 7:49 PM
Subject: [BC-BFLegacyWorks] Now What! !!!!!!!!! part 2
>Engine" light.
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972209400/
a Hallman.
-Matt
>Engine" light.
eGroups eLerts
Yes, I suppose running it at 12psi may have been enough to rupture
the diaphram in the boost solenoid?
adjustable
an
> AVC-R very soon.
I went the 'budget' route and bought the parts for the DIY boost
controller, anyone remember where the web-site is with the
instructions?
gas
Everything is well with all nearly new vacuum hoses. It seems too
consistant for the wastegate to be bad, although I have never had one
fail I would think in the event of a failure I would get too much
boost and a more sporatic behavior?
Thanks for the help
PeteH
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972221657/
adjustable
an
> AVC-R very soon.
instructions?
gas
Thanks for the help
PeteH
eLerts
reason the
early.
Nope, haven't gone there yet (I hate resetting my Eclipse head
unit
If it still being stupid this morning I will do the 'reset'
thing.
If
and grab
> a Hallman.
> -Matt
Isn't the OEM boost controller controlled by the ECM? What do I do,
just unplug it and leave the wire hang, won't I get a 'check-engine'
light?
Thanks guys,
PeteH
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972222551/
reason the
early.
unit
thing.
If
and grab
> a Hallman.
> -Matt
light?
Thanks guys,
PeteH
eGroups eLerts
How do you reset your ECU??? I took battery cable off overnight and didn't seem to work.
a Hallman.
-Matt
>Engine" light.
a Hallman.
-Matt
>Engine" light.
Hey Carl, You have remove the battery cable, for an hour or so. Reconnect the cable. Then start the car, DO NOT touch the throttle or anything else. Let the car idle for about 15 minutes, or until it's up to normal operating temp. Then shut the car off, and that should do it.
Josh Colombo
jcc189@psu.edu
of beats and rhythm" - ME
Sent: Sunday, October 22, 2000 10:26 AM
Subject: Re: [BC-BFLegacyWorks] Now What! !!!!!!!!! part 2
a Hallman.
-Matt
>Engine" light.
eGroups Sponsor
<http://click.egroups.com/1/9658/2/_/_/_/972225027/>
<http://adimg.egroups.com/img/9658/2/_/_ ... 8x602E.gif>
Josh Colombo
jcc189@psu.edu
a Hallman.
-Matt
>Engine" light.
eGroups Sponsor
Hay PeteH, are you looking for this site??
I just bookmark it since I check it out at the i-club. I'm not sure
isn't this the one you are looking for, but it talks about DIY boost
controler!
Check this out!
http://pages.cthome.net/gus/index.html
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972230316/
controler!
Check this out!
eLerts
Yup, that's it! Thanks Ben
PeteH
boost
> controler!
> Check this out!
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972239875/
PeteH
boost
> controler!
> Check this out!
eLerts
Actually, you have to pull both battery cables off and hold them together for a couple minutes.
I guarantee that works, and quickly. Just make sure that if you have a stereo that you've disconnected anything with a capacitor in it first :p
-=[Matt]=-
eGroups Sponsor
<http://click.egroups.com/1/9624/2/_/_/_/972245958/>
<http://adimg.egroups.com/img/9624/2/_/_ ... 468x60.gif>
-=[Matt]=-
eGroups Sponsor
You are welcome PeteH!!
(^-^)...happy to help everybody in the club!!
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972249566/
eGroups eLerts
no. bad. the worst part is, someone will actually go and do that now.
>first :p
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972254912/
>first :p
eLerts
You're definitely askin for trouble with that one....it's called dead short....things spark & fry...not good
Josh Colombo
jcc189@psu.edu
Sent: Sunday, October 22, 2000 4:19 PM
Subject: RE: [BC-BFLegacyWorks] Now What! !!!!!!!!! part 2
-=[Matt]=-
eGroups Sponsor
<http://click.egroups.com/1/9656/2/_/_/_/972255745/>
<http://adimg.egroups.com/img/9656/2/_/_ ... 8x602E.gif>
Josh Colombo
jcc189@psu.edu
-=[Matt]=-
eGroups Sponsor
Plese do not disconnect the battery cables and touch them together
this is asking for big problems$$$$$$$. I have done a lot of work on
these electronic systems and a lot of damage has been done doing
things in this manner. Even using jumper cables in any way can be a
bit risky. The damage is usually not done by the connection but when
the cables are disconnected as the battery looks at the car wiring as
a "ignition coil" and when the field collapses things tend to go
badly.
-- In BC-BFLegacyWorks@egroups.com, "Josh Colombo" <jcc189@p...>
dead
> Josh
> Josh Colombo
> jcc189@p...
> From: Matt Walters [mailto:jonesboy@s...]
or
it's
up to
it.
hold them
if you
it first
> :p
> -=[Matt]=-
> eGroups Sponsor
eLerts
http://click.egroups.com/1/9699/2/_/_/_/972259006/
badly.
dead
> Josh
> Josh Colombo
> jcc189@p...
or
it's
up to
it.
hold them
if you
it first
> :p
> -=[Matt]=-
> eGroups Sponsor
eLerts
I still don't have a good feel for the "official" method of resetting the ECU. The method I tried didn't work and the method suggested here is getting serious mixed reviews.
Does anyone know what Subaru says?????
Thanks,
Carl Andersen
93 Touring Wagon 92000
badly.
dead
> Josh
> Josh Colombo
> jcc189@p...
> From: Matt Walters [ mailto:jonesboy@s...]
or
it's
up to
it.
hold them
if you
it first
> :p
> -=[Matt]=-
> eGroups Sponsor
Thanks,
Carl Andersen
badly.
dead
> Josh
> Josh Colombo
> jcc189@p...
or
it's
up to
it.
hold them
if you
it first
> :p
> -=[Matt]=-
> eGroups Sponsor
Subaru says that if you bring your car into the dealership they will
hook up a unit call a diagnostic scan monitor and charge you for it.
the method of leaving the - connector of the battery off for a while
and then reconmecting it works just fine with the exception of a few
"stored" codes that show sometimes that usually mean nothing
important and I never found any real explanation for.
--- In BC-BFLegacyWorks@egroups.com, Carl Andersen <cdanders@t...>
resetting
here
> Thanks,
> Carl Andersen
on
a
when
wiring
as
> > badly.
> > dead
> > > Josh
> > > Josh Colombo
> > > jcc189@p...
so.
throttle
> > or
> > it's
> > up to
do
> > it.
> > hold them
that
> > if you
capacitor
in
> > it first
> > > :p
> > > -=[Matt]=-
> > > eGroups Sponsor
> > eGroups Sponsor
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972273444/
resetting
here
> Thanks,
> Carl Andersen
on
a
when
wiring
as
> > badly.
> > dead
> > > Josh
> > > Josh Colombo
> > > jcc189@p...
so.
throttle
> > or
> > it's
> > up to
do
> > it.
> > hold them
that
> > if you
capacitor
in
> > it first
> > > :p
> > > -=[Matt]=-
> > > eGroups Sponsor
> > eGroups Sponsor
eGroups eLerts
Not only have I done that, but so has my mechanic. The ECU has battery-backed RAM and that's the only way to quickly reset your ECU (by battery-backed, I mean like two weeks backup time)...
...your call, unless you wanna buy a scanner for it...
-=[Matt]=-
eGroups Sponsor
<http://click.egroups.com/1/9666/2/_/_/_/972275489/>
<http://adimg.egroups.com/img/9666/2/_/_ ... 8x602E.gif>
-=[Matt]=-
eGroups Sponsor
Well, if I were going to do this, I would get a med. sized resistor, 1000k ohm or so and put it between the two cables. This would draw the excess power out slowly, rather than all at once.
Josh Colombo
jcc189@psu.edu
Sent: Monday, October 23, 2000 12:31 AM
-=[Matt]=-
eGroups Sponsor
<http://click.egroups.com/1/9660/2/_/_/_/972304101/>
<http://adimg.egroups.com/img/9660/2/_/_ ... 8x602E.gif>
Josh Colombo
jcc189@psu.edu
-=[Matt]=-
eGroups Sponsor
Hi Carl, This is what Subaru says in the FSM for the Legacy.
Step 1 start engine
2 warm up engine
3 turn ignition sw. off
4 connect test mode connector
5 connect read memory connector
6 turn ign. sw.ON (engine off)
7 check engine lite turns on
8 Depress accelerator pedal completely and then return it to
half-throttle position and hold it there for two seconds.
Release accelerator pedal completely.
9 start engine
10 Check engine light goes out ( if it does not go out it says to
check for trouble code)
11 If light goes out drive at a speed greater than 7 mph for at least
one minute and shift up to 4th speed (MT model)
12 warm up engine above 2,000 RPM
13 check if engine light blinks (if it doesn't check for trouble
codes
14 turn ign. sw. off
15 disconnect test mode connector and read memory connector
16 End
This will work there is two types of memory in the Mitsubihi chips in
the ECU regular RAM and a non-volatile type that is only electrically
erasable and holds a history that can be retrievied by the scanner
this method should erase both but I have seen cases where it will not.
resetting
here
> Thanks,
> Carl Andersen
on
a
when
wiring
as
> > badly.
> > dead
> > > Josh
> > > Josh Colombo
> > > jcc189@p...
so.
throttle
> > or
> > it's
> > up to
do
> > it.
> > hold them
that
> > if you
capacitor
in
> > it first
> > > :p
> > > -=[Matt]=-
> > > eGroups Sponsor
> > eGroups Sponsor
eGroups eLerts
http://click.egroups.com/1/9698/2/_/_/_/972403029/
Step 1 start engine
2 warm up engine
9 start engine
codes
16 End
resetting
here
> Thanks,
> Carl Andersen
on
a
when
wiring
as
> > badly.
> > dead
> > > Josh
> > > Josh Colombo
> > > jcc189@p...
so.
throttle
> > or
> > it's
> > up to
do
> > it.
> > hold them
that
> > if you
capacitor
in
> > it first
> > > :p
> > > -=[Matt]=-
> > > eGroups Sponsor
> > eGroups Sponsor
eGroups eLerts
