So my questions, keep in mind I always read the build threads but am still a bit of a newbie when it comes to this 'in-depth' stuff. Matt, I have done some searching and will continue though I haven't had much luck with the searching on NASIOC but feel free to direct me to keep searching or shot me a link instead of a long response as I have followed your route enough to know it's what I'm looking for.
As I understand it, a Phase I 2.5 bottom end is preferential to the Phase II for this application as it has the higer compression ration ~11.3:1 as opposed to ~10.2:1?
I plan on using my first gen 2.2 heads that have HLA's. I am under the impression that they flow slightly less than my single exhaust port solid rockers that are on my 96'. However, since I have time on my hands I figured I'd give the heads some porting and match the intake ports to the intake manifold - I do have an extra set to experiment on first before I mess with the set that will go on the 2.5 short block. I am also planning on putting in some delta cams with the 220 grind. How's this sounding?
I would like to be able to use my current ECU and wiring. Since I will be using 2.2 heads and the 2.2 intake manifold the sensors should match? I will swap throttle bodies so the TPS will have the correct number of wires. But what about the cam and crank sensors? Also, what timing belt will I be using? I pressume the same one for the 2.2?
It is also my understanding that the 2.2 ECU is a little milder than the 1.8 that Matt used. How much difference is this expected to make?
I read a bit about octane requirements but most of these seemed directed at running boost, which I am not planning on. I usually run on 89, will this work with the higher comp. or will I be looking at running something else?
I think that's all the questions I had for now. Please feel free to give as much or little input as you'd like and I'll keep researching. Like I said, I do have some time and I'd like to be able to do this with a tranny swap (mine's working it's way out...) and do new/stiffer engine and tranny mounts all at the same time both to make the job easier and further my ultimate goal of doing this swap and not having to mess with my drive train (beyond routine clutches) for a long time to come (so I can focus on my 93' build I dream about).
Thanks guys.
