kevlar timing belt?
m44offroad
kevlar timing belt?
anyone have any experience with them? i am in the process of swapping the motor form my 92 wagon into my 90 sedan and while i have the motor out i plan on replacing the timing belt, tensioner pulley, idler pulleys, oil pump, water pump, crank seal, rear main, reseal the valve covers and reseal the oil pan. i have had a couple people suggest using a kevlar t-belt instead of the oem belt and would like oppinions.
siouxbe
- Location: Lat. 40.02 North/ Long 105.25 West/ Elev. 5356 ft. People's Rep. of Boulder
If you have a 2.2l engine ask for the California Spec. T-belt from a Subaru Parts Counter as it is Kevlar reinforced and will change your T-belt change interval from 60,ooo miles to 105,000 miles.
1991 Subaru Legacy BJ 2.2L/2.5LSTi Block Hybrid N/A w/ over 250,000 miles! 1992 Yamaha Seca II 2004 Dyna Super Glide My other car is a Go Kart Redhair...Black Leather...My favourite colour schemes. If it's not Scottish...it's Crap!
If you do that make sure you do the water pump at the same time.
