clutch question
urabusturbo
clutch question
Post by urabusturbo »
I am in the process of swapping in a 95 5mt into my 92 ss and i have hit a snag with the clutch system. Im not sure how to make the ss clutch setup work on this newer tranny. Is the 95+ na trany a cable pull system? Or do i need to convert it? Any advice from somone who has had this issue would be great!
93 Legacy L- FPgreen, 6 speed, Built motor, hydra, etc
92 L wagon.
01 Forester S-DD
91 mr2 turbo
If the newer transmission is a push style setup with a cable, you'll need to convert the clutch setup to a push style setup.
If you do that, I'd recommend converting to hydraulic vs. cable so you don't have to swap out the pedal box assembly. To do this you need the hydraulic slave cylinder, clutch fork, and need to move the pivot ball into the other boss in the transmission case. You may need to tap the other boss.
Post by entirelyturbo »
Will the hydro clutch fork fit on a cable tranny? I didn't think it could.
*Formerly DerFahrer*
Bheinen74
Post by Bheinen74 »
:roll:
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
I deserve that, I guess...
