When you see one you will say fuck thats simple
http://www.xmission.com/~dac/centric/hbc.htm
here you go he's got a whole frigging guide on it
superchips will give you a fancy pants version of the above so you
can adjust it inside you car then give you a really loud dump valve (
you have one already but they won't tell you that... it's silent )
that will screw up your tickover and the diaphram or spring will
break in 6 months so you will need a new one then they will play
around with your ECU so the engine won't cut after 13 psi but so what
because you will be going so stupidly fast before 13 psi you won't
care and/or you will need to make lots of other mods so you engine
doesn't self distruct whist passing the 13 psi barrier anyway.
hey thats freaky your a motorcycle engineer because I drive a Honda
fireblade 900cc 0-60 in 2.5 seconds top speed 175mph but the funny
thing is I feel the speed more in my Legacy, go figure ay! must be
because I am sat relaxed in a nice comfy chiare a bit like watching
telly!
ha ha ha but fuck ! some mental time you've got to drive like a
fucking fruit loop to know whay a Legacy turbo shit can do ay!
cheers
John
--- In
BC-BFLegacyWorks@egroups.com, RALPH <ralph.jarvis@u...> wrote:
> Thanks for the reply John,i guess your up late toomy car is a early
type(it's actualy a 95 M reg)
> but that info normaly confuses.......
> very late reg i guess! (it's also a saloon)(rare!!!)
> so do tell where can i get my hands on
> a manual boost control and guage????
> I'm a motorcycle mechanic by tade so turbos are
> new to me.& What have you heard about superchips cause £400 ish
pounds + fitting is a lot to waste
> on a con..
> all the best Ralph.
> ---- In reply to ----
> From: "John Carlsson" <penty@n...>
> To:
> Subject: [BC-BFLegacyWorks] Re: HellO I am a new turbo lister
> <html><body>
> <tt>
> Well as I said my crappy little boost valve cost £15,took 10 mins
to <BR>
> fit and has probably given me another 30 bhp that equates to 2 bhp
<BR>
> per £1, now thats what I call a bargain!!!<BR>
> <BR>
> your car being a 94 must be the newshape, I think ? so I'm not to
<BR>
> sure how that differs if it is<BR>
> <BR>
> anyways it's nice to see someone else in the UK has a Legacy I was
<BR>
> beginning to think I was alllll alone
<BR>
> <BR>
> let me know how you get on with your upgrades it will be
interesting <BR>
> if removing the cat makes that much difference in the pre boost rev
<BR>
> range and also turbo pick up (lag) , I've heard superchips are a
big <BR>
> fat rip off so be carefull. <BR>
> <BR>
> cheers<BR>
> <BR>
> John<BR>
> <BR>
> --- In
wrote:<BR>
> > Hi John, <BR>
> > My name is Ralph, I have a 94 2Ltr turbo,<BR>
> > and am interested in your mods<BR>
> > (manual boost control)etc.I am having a one off <BR>
> > exhaust made to loose the cats,and will be getting a superchip,
but <BR>
> if I can get more power in the<BR>
> > meantime it would be nice!!!<BR>
> > anyway all the best <BR>
> > Ralph.<BR>
> > p.s I live in Bucks<BR>
> > <BR>
> > ---- In reply to ----<BR>
> > From: "pentypo" <penty@n...><BR>
> > To: "Legacy egroup" <
BC-BFLegacyWorks@egroups.com><BR>
> > Subject: [BC-BFLegacyWorks] HellO I am a new turbo lister
<BR>
> > <BR>
> > <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><BR>
> > <HTML><HEAD><BR>
> > <META content="text/html; charset=iso-8859-1" http-equiv=Content-
<BR>
> Type><BR>
> > <BR>
> > <META content="MSHTML 5.00.3103.1000" name=GENERATOR><BR>
> > <STYLE></STYLE><BR>
> > </HEAD><BR>
> > <BODY bgColor=#ffffff><BR>
> > <DIV><FONT face=Arial size=2>Hi everyone my name is John andI
have <BR>
> a drinking <BR>
> > problem errr sorry I mean my name is John and I have a Legacy
Turbo <BR>
> > problem</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>I have just brought a 4 WD 92 Turbo
<BR>
> Legacy 4 <BR>
> > cam 2L Estate
, I have wanted one for ages</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>Mods so far ( owned it for 7 days)
<BR>
> </FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>Turbo gauge</FONT></DIV><BR>
> > <DIV><FONT face=Arial size=2>Manual varable boost <BR>
> controler</FONT></DIV><BR>
> > <DIV><FONT face=Arial size=2>Impreza Turbo wheels
</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>being a UK car it has a water <BR>
> intercooler as <BR>
> > standard and boost is set to 8.5 psi (.59 bar)</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>not one to hang around I quickly <BR>
> installed the <BR>
> > turbo gauge as the car seemed a little slow, and then popped a
<BR>
> cheepy manual <BR>
> > boost controler in about 4 hours ago!! it certainly helps speed
it <BR>
> up
and <BR>
> > only cost me £15 ( 24$ish </FONT><FONT face=Arial size=2>)he he
he <BR>
> don't you <BR>
> > just lurve turbos</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>anyways all is going great it is now
<BR>
> running at <BR>
> > 11.56psi (.8 bar) sooooooooo why am I here you might <BR>
> ask........well go on <BR>
> > ask......</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>Oh! ok thanks
</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>well as far as I understand it I <BR>
> should be able to <BR>
> > go a little bit higher ....13psi I believe ? before the ECU cuts
<BR>
> off my <BR>
> > fuel ? my question is should I, the motor has done 140000miles
and <BR>
> seems very <BR>
> > healthy the turbo whistles puuuurfickly and as a duo I feel it
can <BR>
> take it, so <BR>
> > here's my question just how far can I realisticly go on the stock
<BR>
> motor bearing <BR>
> > in mind the engine is totaly standard not even a k&N, should I
<BR>
> > stop at 11.56psi or push it higher.</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>Well nice talking to you guys <BR>
> </FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>cheers</FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2>John Carlsson ( proud Legacy owner )
<BR>
> </FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <DIV><FONT face=Arial size=2><A <BR>
> > href="mailto:Penty@n...">Penty@n...</A></FONT></DIV><BR>
> > <DIV> </DIV><BR>
> > <br><BR>
> > <BR>
> > <!-- |**|begin egp html banner|**| --><BR>
> > <BR>
> > <table border=0 cellspacing=0 cellpadding=2><BR>
> > <tr bgcolor=#FFFFCC><BR>
> > <td align=center><font size="-1" color=#003399><b>eGroups <BR>
> Sponsor</b></font></td><BR>
> > </tr><BR>
> > <tr bgcolor=#FFFFFF><BR>
> > <td width=470><!-- |@|begin eGroups banner|@| runid: 9633 crid:
<BR>
> 3553 --><BR>
> > <a target="_blank" <BR>
> href="<a
href="
http://click.egroups.com/1/9633/1/_/_/_ ... tp://click
.egroups.com/1/9633/1/_/_/_/973381008/</a>"><center><BR>
> > <img width="468" height="60"<BR>
> > border="0"<BR>
> > alt=""<BR>
> > src="<a
href="
http://adimg.egroups.com/img/9633/1/_/_ ... rget">http
/adimg.egroups.com/img/9633/1/_/_/_/973381008/target</a><BR>
> (games)468x60.gif"></center><center><font <BR>
> color="black"></font></center></a><BR>
> > <!-- |@|end eGroups banner|@| --></td><BR>
> > </tr><BR>
> > </table><BR>
> > <BR>
> > <!-- |**|end egp html banner|**| --><BR>
> > <BR>
> > <BR>
> > <br><BR>
> > <tt><BR>
> > To unsubscribe from this group, send an email to:<BR><BR>
BC-BFLegacyWorks-unsubscribe@egroups.com<BR><BR>
> > <BR><BR>
> > </tt><BR>
> > <br><BR>
> > <BR>
> > </BODY></HTML><BR>
> <BR>
> </tt>
> <br>
> </tr>
> <td width=470><!-- |@|begin eGroups banner|@| runid: 9664 crid:
3733 -->
> <a target="_blank"
href="
http://click.egroups.com/1/9664/1/_/_/_ ... /"><center>
> border="0"
> alt=""
src="
http://adimg.egroups.com/img/9664/1/_/_ ... ningSmBusi
ness468x602E.gif"></center><center><font
> </tr>
> </table>
> <br>
> <tt>
> <BR>
> </tt>
> <br>
> </body></html>
-------------------------- eGroups Sponsor -------------------------~-~>
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9698/1/_/_/_/973650449/
---------------------------------------------------------------------_->
