The dishonesty that is spring applications!
n2x4
Post by n2x4 »
It seems that pretty much anything posted in here has been hashed over once or twice, but that's besides the point. There's still a "injustice" that I can't seem to figure out.
If you go to look to get new springs, why are they always advertised as like "91-99 Legacy" when we know that there's the difference of the tapered and non tapered rear springs?
I've looked at Intrax, HnR, Eibach, and they all do it. The only exeption to this rule seems to be Whiteline, but that's just because you usually see a picture of the actual springs. All the other companies use just stock photos so they keep you guessing!
So what's a guy to do besides get some of these springs and chance getting screwed? (granted, you could buy the proper top spring perch and top mount if necessary, but you shouldn't have to!)
Same thoughts for those 02-04 impreza springs. Don't those guys have the same problem as us?
I do want to lower my car a little, but since I have the non tapered rears, the only way I feel safe about doing this is just getting some 02-03 stock springs for my 92-94 suspension, and hope it lowers it enough for my liking.
Supid companies and their disregard for proper product application. :(
SUBARUEHS Racing
greg donovan
Post by greg donovan »
why not get the whitelines?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
jamal
Vendor
Vendor
Post by jamal »
I would think that anything listed as 91-99 is not going to fit a 90-91, and that you'll be fine.
I've always seen Impreza stuff listed as 02-03 and 04+
