Cleaning Stuck Horn Buttons on Airbag Steering Wheel (pics!)
Soul Shinobi
Post by Soul Shinobi »
Ever since I got my Legacy the horn buttons were a bit sticky. Once on a quiet residential road, at two AM, I pressed the horn just to see if it worked. It got stuck. It got stuck good. I pressed every corner of the button with no results and resorted to punching the steering wheel with my fist until it finally came free. I was so embarrassed. Since then I vowed to clean those buttons, and clean them damn well. You could try to just pry then out from the front and wind up breaking the surrounding plastic like I did, but why risk making things worse?
Without delay, here is my unnecessarily detailed and long post on how to do this thoroughly without breaking anything.
It is airbag equipped models that have horn buttons, so start by disconnecting the battery because we don't want airbags blowing up in our faces. You should wait over a minute to make sure the backup capacitor for the airbags is discharged as well.
There are four bolts holding the airbag/horn button assembly onto the steering wheel, two on each side.
The two covers can be pried off easily, I use my fingers.
The bolts require a Torx T-30 bit to unscrew. If you're weird like me you can buy one at your local auto-parts store then return it when you're done, so long as you didn't destroy the packaging (I'm like a surgeon).
Removed the large yellow airbag connector first because the wires are shorter, then the white horn connector. To unlock the airbag connector, press down on the top of the connector on the right side just to the right of the green part hooking into it. The green button should then pop out on the left side of the connector.
Bonus question: what's the only visible modification I've made to my Legacy here?
To removed the horn buttons remove the screw from the metal plate and pull the red wire's connector off carefully with some needle nosed pliers.
Next push out the horn button assembly. This is best done by pushing on the edge of the trim colored plastic through the center hole where the screw was. It takes a lot of force for something so simple, that's why it's best to push in the middle so that you don't bend it one way or another.
If there's nothing to get a hold of in the middle you can try here.
The resulting horn button assembly. Notice part of the plastic broken off at the top, that was from me trying to pry the button itself out earlier. I actually spent 15 minute trying to find that tiny plastic piece to glue it back on.
Carefully remove the outer button from its casing by pushing in as many tabs as you can. A helpful friend may aid. Again you can see the piece I broke off from trying to pry the button out while it was in the steering wheel...
Look at that CRAP. I don't even know what it is. Maybe the previous owner spilled coffee on the steering wheel somehow.
Look for defects in the plastic like this and scraped them flat with an exacto knife or something similar.
Also do the same for deformations you might have caused prying the button out, but if you did it right you shouldn't have pried it out.
When reinstalling the airbag/horn assembly after plugging in the yellow airbag connector you MUST push in the green button on the left of the airbag connector before reconnecting battery or the airbag will NOT be enabled and the airbag light on the dash will always be on. In this picture the green button has not yet been pushed in.
Bonus question answer: The gauge needles have been painted red with a Sharpie marker.
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
That's a good unnecessarily detailed and long post.
The bonus question was too easy. :-D
Soul Shinobi
I was worried it was too easy...
I realized when I started typing up the post how absurd it all was, but I had already taken and cropped the pictures...
The reason I went into such anal detail is because I feel that people on this forum rarely go into enough detail on a lot of things. I wanted my experience to be easily understood and reproduced by people who know little or nothing about cars, because I was in that state just seven months ago when I got my Legacy. My learning experience with cars has been slow and difficult because people on just about all forums rarely break things down for those who might be new to working with cars.
-Nick
gto7419
Post by gto7419 »
Soul Shinobi wrote:I was worried it was too easy...
When I first got here, I thought the SAME thing and I still kind of do. On miataforum.com (I also own a miata) there are a lot of writeups like the one above.
Not having enough people like you is the reason all the new people (like me) say "I searched but couldnt find an answer"...
Good job!!!
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Soul Shinobi
Thank you! You alone have made my efforts worth it, I'm so grateful. :-D
I think I'll check out that forum for both the education of it and also because I'm considering going 50/50 on a used Miata with my brother. Thanks again.
-Nick
Carbix
Post by Carbix »
10/10 great job.
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
Brat4by4
Stratified
Post by Brat4by4 »
Great, I need to do this on one of my buttons. :)
Soul Shinobi
You might as well try to clean both while you've got the thing apart, even if one doesn't stick yet.
-Nick
jamal
Vendor
Vendor
Post by jamal »
now you've got me all worried mine are going to stick some time. And I have supertones.
Soul Shinobi
I wonder if that would blow a fuse?
-Nick
jamal
Vendor
Vendor
Post by jamal »
Soul Shinobi wrote:I wonder if that would blow a fuse?
Possibly, but they're run off a relay and have an inline fuse.
magicmike
Post by magicmike »
all new meaning of OCD lol you make me feel normal after seeing this thread lol
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
