How to remove crank sensor???
SergeyZ
Post by SergeyZ »
I am trying to remove the crank sensor from the oil pump housing. I took out the M6 bolt and can spin the sensor inside, but can not remove it.
I tried everything. Prying it up with a screwdriver, pulling on it etc... and ended up breaking the plastic end where it threads in.
How the hell is it held in there?
PhyrraM
Post by PhyrraM »
It should pull straight up after the bolt is gone. Your prolly fighting a ring of gunk on the inner edge. A bad crank seal will sling right there and collect dirt, then it hardens and can make it very hard to pull out.
YMMV
SergeyZ
Post by SergeyZ »
I cleaned up all the gunk and I can see it separate maybe half a mm from the housing but it wont come out.
It is driving me nuts!
How much is a new crank sensor anyways?
