safc II install AND J&S safeguard ultra install
gto7419
Post by gto7419 »
Just finished both installs yesterday... If anyone needs help installing either, let me know... Its awful simple, just a lot of tedious soldering in a tight space...
Anyway, if someone needs them, I can take pics of the mess I made of the ecu harness :-D
On a side note, I noticed that the wire labeled for the map sensor on the pinouts does not exist in my ecu harness - I was always under the impression we had both maf and map sensors???
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
We do have both sensors. It's called a pressure sensor in the wiring diagrams
gto7419
Post by gto7419 »
Ill take a second look... Its really weird because it says map sensor on the pinout, and there really is no wire there...
ramathorn
Post by ramathorn »
zomg. if you could take pics that would be so awsome im looking to hook up an older safc but im sure connections would be very similar.
bcmaxx
Re: safc II install AND J&S safeguard ultra install
Post by bcmaxx »
Just got a j&s ultra for my 93. Looking for some help on install if anyone still has any info on how to install. Sorry to ressurect a thread from the dead!
Are there any online instructions for it so we can review and comment on the install?
bcmaxx
Post by bcmaxx »
Legacy777 wrote:Are there any online instructions for it so we can review and comment on the install?
I'm not sure why but the subaru instructions are eluding me at the moment. This is the exact same http://www.jandssafeguard.com/EclipseInstall.html just ignore the tps and map wires.
The hardest part was getting access to the ecu and getting it all unplugged then all put back in nice.
theres only a few wires for install
-an actual wired ground ( not sheetmetal)
-key on ( must have power when cranking) I used an add a circuit off a 20 amp in the fuse panel
- tap into knock sensor signal wire
- cut ignition one and ignition 2 signal wires, and out j&s unit inline
- add a boost reference hose to the intake
I was at a loss for a good place to install the unit. So I sacrificed the console between the seats. There was just enough wiring provided to make it all the way.
