Replacing the AC belt
jnorion
Post by jnorion »
How the #$%!* are you supposed to loosen the tensioner bolt?
There's MAYBE an inch of clearance down there, not nearly enough for a socket, and the bolt is sunk back in too far to get an open ended wrench in. Is there some special tool I don't know about, or do I have to lift the entire radiator out of the way to get to it?
~Joel
MPtyza
Post by MPtyza »
You're looking at the wrong bolt there. What you want is the upper one, just underneath the belt cover. The one you have circled actually holds that pulley on the tensioner
jnorion
Post by jnorion »
I know how it works... but the one I have circled is tightened down so the other one doesn't slip. To adjust the actual tensioner bolt, you have to loosen this one to allow it to slide up and down. If you try to turn the top bolt without loosening the bottom one, you'll break the bolt and/or strip it.
~Joel
Use a wrench.....it's not too bad, and can be done without removing the fans. However if you need more room, just remove the fan....it's not that hard.
jnorion
Post by jnorion »
Hmm, I was having a lot of trouble getting a wrench in there. I guess I'll try again.
I know I can remove the fan, I was just hoping there was a better quicker way. Thank you!
~Joel
Threshld1
Post by Threshld1 »
I had no problem getting at it with a 3/8th ratchet and shorty 12mm on my buddies 98 OBS and those fans are a lot closer to the block then our leggys
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
jnorion
Post by jnorion »
I've tried... the ratchet itself barely fits. 1/4" of clearance or so.
I'll go back out this afternoon and try with a wrench again. It's getting hot, I want to fix my AC.
~Joel
Threshld1
Post by Threshld1 »
hah ive never owned a car with working AC just tough it out =)
if anything get a box wrench with an angled end and you should be able to get it on the bolt vertically in the channel, it shouldnt be too difficult to get off if you can get a wrench on it, good luck
91 SS AT
jnorion
Post by jnorion »
I toughed it out last summer with leather seats wearing a shirt and tie all summer. I know it's not that big a deal, but the car's equipped with the system and there's a chance all I have to do is replace the belt for it to work. If it takes more than that, we'll see if it's really worth the effort.
~Joel
Yeah...use an open end wrench, not a ratchet
internetautomart
Post by internetautomart »
craftsman sells a socket set that you put a box end wrench on rather than a conventional ratchet.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
Saskatoon Subaru
Post by Saskatoon Subaru »
i just did this today use a 18mm wrench, works no problem, i think it was 18mm anyway
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
jnorion
Post by jnorion »
I tried it with an open ended wrench and couldn't get it... even after soaking with WD-40 it was on too tight and I just stripped the head slightly. But I had to mess with the radiator anyway so I just took the fan off and replaced the belt using a socket. Thanks for all the advice though!
~Joel
n2x4
Post by n2x4 »
When I removed my rad fans, I left the bottom bolts loosened up a little.
That way if I ever need the fans out again I just have to unclip the connectors, unscrew the 4 top bolts for both fans and then the fans will slide right out. For reinstall just make sure that the fans slide back down onto the lower bolts.
SUBARUEHS Racing
jnorion
Post by jnorion »
Yeah, I did the same.
~Joel
