Seems like every 2 or 3 days Im blowing a coolant bypass line. 1st it was the line that lead from my coolant resivoir to my turbo. Then as soon as I get that replaced, 3 days later I blow a line leading from the coolant passage to the manifold.
Today (3 days later) on my way to work, i blew yet ANOTHER coolant line. This one runs on the passenger side of the car, looks like it comes from a hard line to the bottom of the block.
WTF?? Any idea why all these lines are blowing? Im wondering if my radiator cap is faulty, and not relieving pressure? I guess I'll replace that when I do this 3rd line.
-Brian
Blew ANOTHER coolant line!! 3rd one in 2 weeks???
TheSubaruJunkie
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
not8player
TheSubaruJunkie
thehookeup
is your coolant clean? does it look like you might have blown a head gasket ? that will build pressure fast
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
rallysam
that's what I'd check, toothehookeup wrote:is your coolant clean? does it look like you might have blown a head gasket ? that will build pressure fast
'00 Impr RS - sold
TheSubaruJunkie
I cant check my coolant cause it wont stay in the car long enough to turn dirty. Im running straight water now. The car doesnt act as if it has a blown head gasket.
Usually i would run the car without a radiator cap to look for bubbles or exhaust in the coolant. The turbo doesnt have a cap on the radiator, and when I run it without the cap on the coolant tank it doesnt show signs of exhaust or any bubbles in the coolant.
What other methods should i use to check the gaskets? Maybe a compression test is in order.... if only it werent such a pain in the ass to get the spark plugs out :X
-Brian
-Brian
1986 Toyota 4Runner
1986 Toyota 4Runner
I had a bad cap once, and it did something like that (on a different car) I also had a blown head gasket on a car that was pressurizing the coolant system... you should be able to hear it if that were the case, because the engine gurgles a little bit after you shut it off, or the cap would hiss due to the extra pressure after you shut off the engine... but thats experience with GM vehicles, might not work that way with this car... like comparing apples and oranges
The car may run just fine with a blown headgasket Brian. Mine did. I had an oil leak in my headgasket that went from an oil line to a headbolt hole. You couldn't tell other than the oil was coming up a little tube that was open to the headbolt just above the head.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
