> Hi,
> what is an interference engine design?
basically it means if the cams aren't timed correctly, the piston can hit
the valve if it comes up and the valve is open.
like if a timing belt breaks when the valve is open, the piston will hit the
valve when the piston reaches TDC :^)
Hi does anybody know if my 92 4wd turbo legacy has this engine ? I am getting worried if my cam belt breaks
cheers
John
eGroups Sponsor
<http://click.egroups.com/1/9657/1/_/_/_/973902135/>
<http://adimg.egroups.com/img/9657/1/_/_ ... 8x602E.gif>
Don't worry about it. Unless you have a 2.5 - then you will mess something up for sure. If you have the NA 2.2 you won't have a problem.
-Sambo
-----Original Message-----
Sent: Friday, November 10, 2000 3:10 PM
To: Legacy egroup
Subject: [BC-BFLegacyWorks] what is an interference engine design
> Hi,
cheers
John
eGroups Sponsor
<http://click.egroups.com/1/9623/1/_/_/_/973902243/>
<http://adimg.egroups.com/img/9623/1/_/_ ... 468x60.gif>
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
I have the 2L 4 cam turbo (dohc) UK model (ej20 engine), I am really worried my belt could snap and send my engine into oblivion.....
cheers
John
----- Original Message -----
To: 'BC-BFLegacyWorks@egroups.com'
Sent: Saturday, November 11, 2000 12:17 AM
Subject: RE: [BC-BFLegacyWorks] what is an interference engine design
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
<http://click.egroups.com/1/9649/1/_/_/_/973904317/>
<http://adimg.egroups.com/img/9649/1/_/_ ... 8x602F.gif>
cheers
John
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
The EJ20 is an interference engine, and belt replacement is recommended every 70,000kms and you may as well do the hydraulic tensioner whilst you are there, ...this is easy to perform as long as you are careful with retiming the engine. The idler pulleys can use replacement at subsequent changes.
John
To: BC-BFLegacyWorks@egroups.com
Sent: Saturday, November 11, 2000 21 PM
Subject: Re: [BC-BFLegacyWorks] what is an interference engine design
cheers
John
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
<http://click.egroups.com/1/9653/1/_/_/_/973904953/>
<http://adimg.egroups.com/img/9653/1/_/_ ... 8x602E.gif>
John
cheers
John
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
Poo!
Thanks I shall do it asap
Sent: Saturday, November 11, 2000 15 AM
John
cheers
John
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
<http://click.egroups.com/1/9630/1/_/_/_/973906350/>
<http://adimg.egroups.com/img/9630/1/_/_ ... 468x60.gif>
John
cheers
John
-Sambo
To: Legacy egroup
> Hi,
cheers
John
eGroups Sponsor
