Inhibitor switch
Tleg93
Inhibitor switch
Post by Tleg93 »
I've been throwing a code 51 (inhibitor switch) on my legacy. What is the inhibitor swtich, where is it and how can I get to it? Any info would be appreciated.
--Scott--
1991 - Rio Red SS
It's mounted on the side of the transmission, and basically is the electronic switch on the transmission that tells the TCU/ECU what gear the Trans is in.
gto7419
Post by gto7419 »
Hmmm, there are two of these sensor things on my tranny. One for each shaft?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
You see where the shifter cable goes
http://www.surrealmirage.com/subaru/ima ... P_3217.JPG
Where it attaches to the trans is the inhibitor switch. That whole assembly is the switch.
Tleg93
Post by Tleg93 »
Thanks Josh, that clears that up.
--Scott--
1991 - Rio Red SS
