Adding Subaru Genuine Keyless entry
NuclearBacon
Post by NuclearBacon »
So i just added a keyless entry module to my parents 2000 Yukon, and literally it was this black box that snapped on top of the ECU, and you hold the keyfobs down and poof! that was it
i was curious about adding keyless entry onto my Legacy (92 touring wagon) and if it has a similar option? mine has no keyless entry as it sits, and then i thought about how i dont have a power lock on my drivers door (that i know of)
just curious if anyone has added it (besides adding an alarm)
thanks!
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
know1
Post by know1 »
just go to an alarm place and get both at the same time. Should lower your insurance rate a bit having the alarm.
Threshld1
Post by Threshld1 »
$8.73 every 6... WOOOOO! :roll:
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
NuclearBacon
will they install a power lock solonoid on the driver door (with the alarm installation?) never had an alarm actually installed.
-Luigi-
Manarius
Post by Manarius »
They will install a solenoid on only the driver's door. Because of the way the central locking system works, it only takes on solenoid to unlock or lock all doors. Aftermarket systems for these cars work the same way.
