NA front diff in Turbo tranny?
Splinter
Post by Splinter »
My friend is selling his 4.11 rear LSD, and Im doing an EJ225 swap in my RS2.5 in a couple months, so I was gonna swap my spare turbo 5MT into the RS
Having the 4.11 gears would be pretty sweet.. anyone know if it'll fit?
Splinter
Post by Splinter »
bump
probably...
Does your friend have another 4.11 rear LSD for sale?
Splinter
Post by Splinter »
No, he got one for his build but then decided to go 4.44
All_talk
Post by All_talk »
Remember, the diff has nothing to do with the gear ratio, its the ring gear mounted on it. And if you change the ring gear you have to change to the matching pinion shaft too. As long as you are willing to go that deep into the trans and can set up the gear mesh correctly it should work, I beleive the parts will fit.
Gary
