I recently acquired an interesting engine, please advise...
Matt Monson
Post by Matt Monson »
So,
What's I've got is a DOHC Ej20 from a 1990 Legacy. This however, is an NA engine with the highest domed pistons I have ever seen in a Subaru. It's also a closed deck block. Furthermore, the cam grind is different than the EJ20G, even though the heads look identical. Lastly, the manifold is this crazy thing with some sort of vacuum actuated flapper box that varies the airflow in the manifold runners, kind of like Audi's vario-ram system. I've done a bit of searching,but can't find much since I lost some old links I had to AUS spec stuff.
So, anyone know anything about this engine? What kind of power does it make? Cam grind specs? Etc. Etc. Anything you got would be helpful. I am trying to decide what to do with this thing...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
PhyrraM
Post by PhyrraM »
Look/search for an SAE paper published by Subaru about 1989. It has info about this engine.
I've got it on my FTP server, So I can email it to you if you would like.
PhyrraM
Post by PhyrraM »
SAE publication 890471.
150ps@6800rpm
17.5kgf/m@5200rpm
redline@7500rpm
Matt Monson
I thought I had seen somewhere that it was around 150. 7500 rpm redline? No Fing way. It's got the little stub rockers like all the other Legacy Ej20G's...
Suby Hai!
greg donovan
Post by greg donovan »
before rally america increased the displacement limit for G2 i was looking into finding one of these for my legacy to run in G2. of course i ran out of money to throw away around the same time so...
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
PhyrraM
Post by PhyrraM »
Got a temp domain name for my FTP.
Try this:
ftp://nathanandtyler.com/SHARE1/SAE_boxer.pdf
Matt Monson
Got it. Thanks...
Suby Hai!
stipro
Post by stipro »
That sounds to me like a VZ Type R motor.
skid542
Post by skid542 »
Pics?
It doesn't surprise me that you ended up with an engine like this, you always get the cool toys :).
Lee
Matt Monson
stipro wrote:That sounds to me like a VZ Type R motor.
Huh?
Suby Hai!
DLC
Post by DLC »
I've had this for a while but for some reason I can't find a link to it on my site. It was in the gallery, and here's a link to its album:
http://gallery.legacycentral.org/v/Libr ... /saeboxer/
Legacy Central
stipro
Post by stipro »
Huh?
They made a japanese Legacy model called the VZ, and you could get the Type R version. It came with a 2.0L ej20G n/a. Higher compression, 9.7:1, for more power, 150ps. Its trim level was that of the RS/GT.
IronMonkeyL255
Post by IronMonkeyL255 »
That was a VERY interesting read.
Rio Red '91 Legacy SS
jackmore
Post by jackmore »
I have a VZ-R
Not that it's necessarily needed, but I've got that on my site too
http://www.surrealmirage.com/subaru/tech.html
All_talk
Post by All_talk »
You just gotta love the Google image search...
From this site
http://www.subarist.com/~qrp/motor/sale_VZ-R.html
Looks like a pretty cool ride to me.
Gary
jackmore
Post by jackmore »
Crazy as. Mine is a sedan version and it is a bc5 not a bf5. Will try and put up some pics for you guys if ya like so watch this space
IronMonkeyL255
Nice.
It looks like a fun, odd engine.
Cram it into something lightweight and have some crazy n/a fun.
Matt Monson
I may be getting a '95 LS wagon with blown HG this weekend. I am considering putting the 2.0l in there...
Suby Hai!
SemperGuard
Post by SemperGuard »
some more info here; http://bbs.legacycentral.org/viewtopic.php?t=31215
not much more info though. But yeah ,that definately sounds like an EJ20D, though I didn't know they came with closed deck blocks.
jackmore
Post by jackmore »
So what are your plans for the engine? Will you keep it n/a or will you juice it up a bit?
gto7419
Post by gto7419 »
jackmore wrote:So what are your plans for the engine? Will you keep it n/a or will you juice it up a bit?
I think the point of this being a cool engine is the fact that it is a higher compression naturally aspirated engine.
Basically adding a turbo to this engine is pointless....
Matt, what ecu are you going to use for this thing?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
jackmore
Post by jackmore »
How much more power can you squeeze out of it? I want some ideas as to what to do to my car
jackmore
Post by jackmore »
Here are the pics of mine. The car needs a clean though. I have changed a few small things on it such as the silver door handles and the silver window trim on the doors. It needs a bit of body work now.
theflystyle
Post by theflystyle »
envy: rear wiper
-94 Legacy L
-94 SVX LSi
-08 Legacy 3.0R
