Pulling pins on the ECU plugs.
adema2626
Post by adema2626 »
Couldn't find any threads so im asking how do you pull the wires from the ECU plug? I'm trying to pull them out so i can move them around.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
PhyrraM
Post by PhyrraM »
Hard to explain, but I'll try.
First you'll have to make, or buy, a tool. A flattened Paper Clip works well. Even better is to take a 1/16 or so allen wrench and grind it flat.
The metal terminals are crimped to the wires. The terminals are held into the plastic connector with a locking tab. You need to locate the locking tab and lift it with the tool you made. As you lift give a slight tug on the wire and the terminal should pop out.
I'll try to update with a few pics in about an hour or so.
